Results 1 to 3 of 3
Thread: Thoughts regarding power input?
    FLAC Skraggy_uk's Avatar
    May 2002
    Warrington UK
    Has anyone with an Epia or SBC based system building a one or two din usint considered hooking up an ISO style connector adaptor to the PC's power supply?
    I wonder if an ignition live based system could be used with an Opus, to trigger start and shutdown?
    4x4 in a turbo stylee.
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by Skraggy_uk
    Whaddyoumean?
    May 2002
    Warrington UK
    If going headunit less, run the audio from the soundcard to the amps, fair enough. But rather than hackup and add to the cars wiring, what about buying in an adaptor to that would normally be used to convert a non ISO stereo to ISO fitment.
    Then use the power sections of the conector to connect to the Opus, making it more of a standard connection fitting into the cars wiring, rathe rhtan hacking about and adding on. You may need to run one fused live line straight to the connector rather than the low current memory connection, but using the ignition live on the ISO to do the startup/shutdown connections on the Opus? Probably a very silly idea, but through anything that makes them more like a standard car audio install will make them easier to fit.
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. Contec 10.4" power...
    By Pu_DeKcUf in forum Power Supplies
    Last Post: 02-06-2004, 02:55 AM
  3. Aus Mainly: What do people think of this (250W power supply)
    By king_rich18 in forum Power Supplies
    Last Post: 01-28-2004, 11:15 PM
  4. getting an odd motherboard to power on
    By karmann in forum Power Supplies
    Last Post: 11-28-2001, 06:27 PM
  5. HELP!! Power Supply wont supply power
    By Saab in forum General Hardware Discussion
    Last Post: 08-28-2000, 10:33 AM
