No.
but I think a hint is that you did XP updates.
Boot from the XP cd. see if it will repair the install.
If you cannot...then put a different drive in the machine. Recheck the bios settings.
Standard PC troubleshooting.
Has anyone ever had an m10000 krap out on them , ok, so it's not dead , but the primary ide channel is , it doesn't recognize any devices anymore and i didn't do anything out of the ordinary to it , just booted it a few times , did xp updates then pfft gone , 2ndary works fine still , primary gives "verifying pool data" and then it goes to invalid disk , blah blah and press enter.. just sucks gotta rma it , just got it yesterday.. --Josh
No.
Yah.. I tried that , however , bios doesn't see it either , won't see any drive on that controller , I reinstalled xp on the drive and tried though just for a laugh and same thing of course , reset bios same thing , I have a new board on it's way.. =\
Yes, =\ my first thought was omg drive died , switched the drive to 2nd channel worked fine.. at that point i knew it wasn't the drive or the cable but tried it anyway, new drive <--even a cd drive and new cable.. same results , bios doesn't see them and windows <--if i put the hd on the 2ndary channel defiantely doesn't see them
This definately rings a bell with me! I had the same problem when building mine, f****d if I can remember how I sorted it though!Originally Posted by Bikr
Sorry, if I find anything in my sieve-like memory I'll let you know.....but it did work in the end!
I had that problem also however mine turned out to be the cable. It was really strange because when I plugged my hard drive using that cable in the primary IDE channel, it would not work but when I put the same cable in the secondary it worked. At first I did not believe it but after trying consistently for two days with the same results over and over again I got fed up and pulled a cable from my desktop and that solved my problem. Funny thing is that cable now works fine in my desktop. When I'm up to it I plan on changing it before I start having problems.
hmmmm I think I planned on changing that cable over two months ago
2002 Chevrolet Avalanche
Zotac NForce 610i ITX, 2GB RAM, 2.6 GHz Intel Pentium Dual Core CPU, 320 GB Hard Drive, 12' VGA touchscreen monitor, 3D mouse
My Worklog : http://www.mp3car.com/vbulletin/work...avalanche.html
