Page 1 of 7 1234567 LastLast
Results 1 to 10 of 68
Thread: force xp to rescan usb devices?
    Variable Bitrate fly_dutchie's Avatar
    Feb 2004
    Amsterdam
    Question force xp to rescan usb devices?
    Does anybody know a way to force XP to rescan/reset all usb devices? Or through a helper application?
    Sometimes after startup/reboot my usb gps does not get recognized. I have to manually remove the usb plug and insert it again to make it work.
    Michael
    "It does not understand, if it does not ride."
    M10000, 512 Mb, 2,5" 40G, Slim DVD, Opus 90W, Xenarc 7", Leadtek 9532 GPS,
    RoadRunner, MapMonkey, Pioneer HU, Pioneer 4 ch 400W, Kappa 6.5, Basslink X 200W
    Low Bitrate SportivoWISH's Avatar
    Jan 2004
    Singapore
    Quote Originally Posted by fly_dutchie
    Michael
    Use devcon.exe to unload and reload the Devices. I am using that to reset my D-Link usb radio.
    MediaCar
    Girder with Igor plugin
    EPIA-ME6000 w 256MB DDR
    Morex 55W PSU
    12VDC Regulator
    IBM DJSA-220 20GB
    90% completed in a plastic case (8"x10"x2.5")
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    Quote Originally Posted by SportivoWISH
    Ooooh....! Fancy giving us the command line you use for the D-Link?
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Feb 2004
    Amsterdam
    Thanks SportivoWISH!
    Would you run this command line utillity by 'hand' every time at boot/hybernate?
    Or is there a way to automate it?
    I just got the D-Link Radio, guess that needs resetting than as well...
    Confused, you have the same problem with D-Link or GPS?
    I think the command line options relate to specific device numbers.
    In other words, is it possible to make a script that runs at boot/hybernate
    to reset/rescan all USB devices that works on different machines?
    I have the feeling some other M 10000 users could use it too.
    I'll get to the bottom of it tonight and post back. Don't wait up all night.
    Michael
    devcon.exe
    Aug 2003
    Plymouth , MN
    Thumbs up Forcing XP to rescan devices
    Right click on your "My Computer icon on your desktop on in the start menu and select properties. Your system properties dialog box pops up. Go to the hardware tab and click on the "new hardware wizard" . when the wizard strts follow the step until the computer starts scanning for new hardware. At this point it will locate the usb devices and automatically install drivers. You may cancel the wizard at any time after it locates your missing device as you will not neeed to go through alll the steps . Hope this helps. Let me know
    2002 Chevrolet Avalanche
    Gigabyte Z97 mITX Intel Mobo, 8GB RAM, Intel Core i5-4590S 3.0GHz Proc, 320 GB Hard Drive, Dual 12' VGA HDMI DVI touchscreen monitors,....
    http://www.mp3car.com/show-off-your-...avalanche.html
    Maximum Bitrate none's Avatar
    Sep 2003
    USB devices not detected at startup or resume is a known bug in Windows XP and Windows 2000. Windows 2000 SP4 solves this, and the next as-yet-unreleased Service Pack for XP does the same. Until that service pack is released, there is a standalone patch for XP that fixes it, but you have to ask Microsoft for it, it doesn't seem to be available otherwise.
    http://support.microsoft.com/default...b;en-us;810090
    Sep 2003
    Quote Originally Posted by Dluvr22
    95 Toyota 4Runner
    Elliott's MP3 Runner
    Components of my setup takes up way more than 250 characters and no matter how I tried to make it fit here it just wouldn't so please check my page.
    Some of the popups that your webpage loads cause Netscape to lock up.
    And I clicked around for a while and still found no information on any computer. Edit: found some pics on page 2, but no info. Care to elaborate on your setup?
    Aug 2003
    Essex, England
    Every time I try to use my D-Link after standby/hibernate, the computer will BSOD and restart itself. I haven't yet tried unplugging it and plugging it back in after it resumes from standby...will try that tonight.
    It gets annoying, as it always seems that the time i want to use the radio is after the system's already gone to and resumed from standby.
    My Sapphire GPS mouse is perfect, couldn't be any happier with it. Almost instant lock, and works perfectly after resume from standby.
    Garry
    www.aimee.cc
    Jan 2004
    Singapore
    Michael
    devcon.exe
    I have writtten a batch file to unload and reload the Device Driver, activate it via a touch of remote using Girder. It is working perfectly.!
    Rescanning doesn't work, u need to Disable the Driver, Re-Enable it.!
    MediaCar
    Morex 55W PSU
    12VDC Regulator
    IBM DJSA-220 20GB
    Jan 2004
    Singapore
    Quote Originally Posted by none
    It has already been fixed on XP SP1. The D-Link Driver is not a true XP driver, therefore it is still giving problem upon system rebooting from hibernation.
    MediaCar
    Morex 55W PSU
    12VDC Regulator
    IBM DJSA-220 20GB
  1. Win XP Hibernation and USB Mass Storage
    By leenas in forum Software & Software Development
    Last Post: 10-28-2003, 06:34 PM
  2. powering some usb devices
    By cubanmoses in forum General Hardware Discussion
    Last Post: 10-08-2003, 12:23 PM
  3. Replies: 4
    Last Post: 09-12-2003, 06:15 PM
  4. Haicom USB and XP!
    By Daz in forum GPS
    Last Post: 08-29-2003, 11:33 AM
  5. USB Devices, and Hibernation / Suspend to RAM
    By t0ffluss in forum General Hardware Discussion
    Last Post: 01-06-2003, 09:40 AM
