Results 1 to 8 of 8
Thread: soundcard/minijack question
    Maximum Bitrate jusatry's Avatar
    Nov 2003
    Question soundcard/minijack question
    so i just got an M-audio Sonica theater card, and it does up to 7.1 surround sound through 4 mini-jacks (1/8"). My question (one which may pertain to people using onboard 5.1 sound too) is in regards to the center/sub line. I am going to be running 4.1 surround, with the 4 channels going to FR, FL, RR, RL and the sub line going to my amp in the trunk.
    When i plug a mini-jack into the center/sub line, how do i know which one is going to put out the sub line?
    Im assuming there is a difference between center out and sub out Also, my sub line would be a mono out (1 RCA plug), but my current amplifier (though it is a mono amp) takes 2 rca inputs. should i just split the mono line out into stereo sound at the soundcard and run stereo wires back there to the amp?
    For those curious i am running a cadence A7+HC amp with a JL 12W6v2.
    Thanks for the input.
    Nov 2003
    bump
    anyone? any tips?
    Constant Bitrate P4_2.66GHz's Avatar
    Feb 2004
    I think the "Left" channel output from that connector would be the sub output and the "Right" channel output is the center.
    Your amp may be able to accept just 1 channel. I would Y-split it just in case.
    I have not done the above mentioned setup, so it's only theory.
    Maximum Bitrate brrman's Avatar
    Aug 2003
    Indianapolis, IN USA
    for the mono signal - yeah just split it and send it to the 2 rca's on your amp. I assume you are bridging your amp?
    Can't help you with the sonica problem though, sorry
    Car: 2000 Audi A4 Avant 1.8t
    Carputer 2.0: removed. Back to stock.
    Dec 2003
    Surrey, BC, Canada
    Sorry but this has to be said, RTFM!
    The manual for the sound card should say what signal is carried on each left/right channel for each minijack.
    Nov 2003
    Thank you everybody
    Bobby,
    I did read the manual, but apparently missed the one sentance i needed "the white RCA is the first channel listed, Red is the second."
    I appreciated your hesitance in throwing the RTFM out there, but it was just what i needed
    As for the amp, upon poking my head in my trunk for the first time in a while, my amp is a stero amp, so i guess i can jsut split the mono RCA into a stereo cable carriing the same channel on both lines. I hope it doenst sound worse
    We will see, its a pretty nice/smart amplifier, so im sure it will be okay. I am not sure if i need to/want to bridge it, since it already is too powerful for my sub and my gain cant be set higher than 1/4 of the way up. Should i bridge it if i am using a mono channel in?
    Newbie neutral's Avatar
    Nov 2003
    South East PA
    Quote Originally Posted by jusatry
    Nice amp choice. That amp can handle alot more than that sub, a little FYI
    I was sponsered by cadence in my 2000 celica, back in 2000.
    Nov 2003
    Quote Originally Posted by neutral
    Thanks!
    I bought it from a friend back when i was using a 10W7 (which i am now selling becuase the JL slot ported box is HUGE and i drive a litle A4, but i dont have the rescources to build a box out of 1" MDF wood.....I figure one day i may get a second 12W6v2 and build a fiberglass enclosure for both of them
    And i will have an amp to handle both of them!
  1. quick fuse question....
    By jusatry in forum General Hardware Discussion
    Last Post: 02-23-2004, 11:54 PM
  2. Replies: 5
    Last Post: 02-20-2004, 02:08 PM
  3. pwer supply question....dc-dc
    By walid_bmw in forum General Hardware Discussion
    Last Post: 10-02-2003, 04:55 AM
  4. Datalux question
    By ddt in forum LCD/Display
    Last Post: 09-27-2002, 12:02 AM
  5. lcd power question
    By jrbless in forum LCD/Display
    Last Post: 04-07-2002, 01:27 PM
