Results 1 to 7 of 7
Thread: Astec Laptop Supply - Please help!
    Mar 2000
    Orange, Ca., USA
    Post Astec Laptop Supply - Please help!
    Greetz all,
    I just recived two Astec Laptop Supply from mpja and there was no info/spec included with them... If someone would be so kind as to point me to a URL with some more info. on them I would be very greatful.
    lov ya,
    lina
    lov ya,
    lina
    Jan 2000
    Post
    Hi friend,
    I don't remember the URL where I got it, but if you email me I can attach it and send to you
    [email protected]
    Registered User
    Apr 2000
    New Concord, OH, USA
    Post
    If you goto page two of this message board the info you are looking for is under the post DC-DC MECI laptop supply it is the same psu. I have two also and will be doing the wiring this week. I did get some specs with mine from MPJA.
    Jul 1999
    West palm Beach , Fl, USA
    Post
    How hard are they to actually wire up ? are you both going to use 2 , or can i get away with using 1 if I only want to run my mobo and HD?
    Josh
    Registered User
    Apr 2000
    Post
    Haven't done it yet but I plan to use half of an IDE cable pluged onto the 20 output pins. Going to try one first. If that doesn't work I'll use 2.
    Apr 2000
    Post
    I have the manual on my web site for this power supply.
    www.mattman.com/mp3
    Registered User
    Apr 2000
    Post
    I believe that the MECI instruction sheet lists pin 1 as a ground but I have read on other specs that it is -5VDC. By the way great design Matt. I have been looking for a case just like what you have. We do not have an Office Max but I will check at Staples. I have almost the same exact componets you have so it should fit. Thanks for the info.
    If you are looking for the power supplies to start your business I know www.mpja.com had alot when I ordered my 2 a couple weeks ago.
