I haven't seen a Baby AT board for while, so I don't remember the specs on the motherboard mounts and slots and such. But it shouldn't be too far from a microATX motherboard. So you could pick up a microATX case and use it.
You may have to modify it a bit, and you will definitely have to get one of those ATX to AT power supply adapters. (I think www.cyberguys.com has them) Also you will NOT be able to use the rear face plate that covers the ports. It won't match your Baby AT ports, but the open rectangle where the face plate goes should be big enough to allow access to all of your ports.
Also, you may have to drill/tap a couple new motherboard mount holes, but that's better than building a whole case. Below is a link to the .PDF of the microATX motherboard spec. Use it to compare to your current motherboard and see if a microATX case will work for you.
Pay special attention to the motherboard mount layout, and the height constraints section.
http://www.formfactors.org/developer...matxspe1_1.pdf
Good luck,
Tom
LinkBack URL
About LinkBacks
these boards, and
online vendors, and haven't had much success at all.
