Results 1 to 6 of 6
Thread: del
    Mar 2004
    Question del
    del
    Feb 2004
    Elmira NY
    get a 4 channel amp. chain the front 2 speakers together. and the rear have thare own channel's and thare should be a level nob on the amp so you can turn that down so you dont go deff
    so if your front need more power. turn up thare level higher then the rear..
    Low Bitrate 20mg's Avatar
    Oct 2007
    chico ca
    b) wire the computer --> aftermarket amp --> stock amp, and use all 6 speakers (the 200W amp will replace the headunit's 18W amp, hopefully nothing will blow up)
    if you can figure out what is the inputs and outputs on ur stock amp u wont even need the aftermarket one. if you arent planning on using a deck and are gonna rune just the car pute. then its possible to take the deck out get the wires that come out of the deck. the green purple white and grey are all to the amp so if you connect those to rca by splicing its possible. may take a few hours but its cheap. just remember on a rca the wire that runs in the middle is positive so run the wires with the black line to them. if u need a more detailed plan id be happy to help.
    Constant Bitrate stealinfool's Avatar
    Dec 2005
    Orlando
    Quote Originally Posted by 20mg View Post
    (emphasis mine)
    OP was right with C. Get an line out converter so your stock amp thinks its getting input from a headunit.
    You don't want to amplify an amplifier. You'll fry the stock one for sure.
    If you want to simply replace the stock amp then you'll need to provide the proper wattage to the stock speakers with an aftermarket amp, otherwise you'll blow the stock speakers. (You'll probably want to upgrade/replace the speakers anyway over time) This may require several separate amps or one big amp to be done properly.
    Oct 2007
    chico ca
    Quote Originally Posted by stealinfool View Post
    (emphasis mine)
    i was trying to explain how to run the stock amp off the computer.
    Feb 2006
    Might be worth saying what car it is, and what model the OE amp is.
    To see if anyone has got any info/hack/workaround for it.
  1. How2 control CarPC from key fob....
    By NotchbackVW in forum Power Supplies
    Last Post: 09-21-2007, 06:27 PM
  2. PC > AMP
    By sss-610 in forum Newbie
    Last Post: 01-28-2004, 03:07 PM
  3. A heatsink case for small PC (like a power amp style)
    By phoTToniq in forum General Hardware Discussion
    Last Post: 08-27-2003, 11:15 AM
  4. Would this motherboard make a good Car PC?
    By pigseye in forum General Hardware Discussion
    Last Post: 12-27-2001, 06:33 PM
  5. Easy head unit question, and PC to amp question.
    By dudah85 in forum General Hardware Discussion
    Last Post: 09-09-2001, 04:57 PM
