Results 1 to 6 of 6
Thread: [B]How long is too long?[/B]
    Constant Bitrate c0rrupti0n's Avatar
    Mar 2004
    Miami
    Question How long is too long?
    I plan to hook up a LCD, touchscreen, cd-rom drive, 2 hard drives, usb cable from the trunk (carputer CPU) to the dash board. Few questions on this:
    - How long can a VGA cable be extended before it looses quality or signal.
    - How long can an IDE cable be extended before it looses quality or signal.
    - Are there signal repeaters for these situations?
    - Where can such cables be purchased or do they needs to be custom fashioned.
    - Is it better to just make my own? (splice cables my self)
    Thanks so much in advance...
    Mar 2004
    I have 2 computers racked up across the room in my computer room that I use in my office. They both work fine over a 50 ft vga Extension cable + Monitor cable. Same for the PS2 KB/Mouse. They say you can go about 75 feet maximum before the video starts getting flakey.
    IDE cables can be a maximum of 24 inches. Thats it. SATA can go a bit further but it's still only like 5-10 feet (guessing). Why would you ever want to mout these away from the CPU/PS? Doesn't make any sense. There are solutions to remote mount storage, but they are expensive.
    There are lots of places for cables www.atozcables.com is ok, just pick out what your looking for and search google for it.
    USB you didn't mention, but it only works to 5 meters (16 feet). If you have to go further, then you need an active usb extension cable. They have them for 1.1 and 2.0. Here's an example: http://www.sewelldirect.com/USB2Exte...USB_2_Repeater
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by chance_11
    wellllllll - I need a 15ft IDE cable
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    I'm guessing PC in the back, IDE DVD/CD in front. Seems he'll need a USB DVD/CD?
    Constant Bitrate Aftaab001's Avatar
    Mar 2004
    Kent, UK
    http://www.veryveryexcited.com/archives/000013.html .search for IDE to USB 2.0 converter. The power is the tricky bit, as it comes with a AC-DC converter you have 2 options of powering it, either using power inverter or making a LDO circuit for the specs of 1 : dc [email protected] and
    2: dc+12v @1.5A
    (This means you will have to modify the power input bit)
    Newbie Angelica's Avatar
    Nov 2003
    So. California
    You might want a look at this IDE to USB adapter you can get it for about $40.00
    http://www.datoptic.com/usbfwfr.html
    By the way the maximum spec for IDE cables is 18 inches but I have had no problem running cables as long as 36 inches inside server cases.
    Hope this helps
  1. Good Setup? (sorta long)
    By nick9871 in forum Newbie
    Last Post: 02-26-2004, 10:11 PM
  2. How long can you run your Carputer???
    By imi1232000 in forum General Hardware Discussion
    Last Post: 02-04-2004, 11:38 PM
  3. Sooo ****ed right now---lillyput--very long.
    By liquid_smoke in forum LCD/Display
    Last Post: 11-28-2003, 04:29 AM
  4. never lose focus
    By marsjell in forum Software & Software Development
    Last Post: 08-12-2002, 02:18 PM
  5. serial port shutdown signal
    By moahdib in forum Power Supplies
    Last Post: 08-03-2001, 09:52 PM
