hope u guys can see the images cuz I can't see them anymore
I have an Epia M10000 With the Via CLE 266 chipset. Recently my computer started shutting off by it self due to a device failure. I found out that the failed device happens to be the graphics chipset. At first there was no display adapter in the list of hardware devices. Now after trying to manually install drivers from my hardrive I get this
when I click on properties it says the device has been stopped . I also tried installing the drivers from the CD that came with the mobo and the drivers from VIA's website and I get this
" Setup was unable to complete installation Check the progress log in your windows directory for more details"
Has anyone experienced this before? If so can anyone help with this?
2002 Chevrolet Avalanche
Zotac NForce 610i ITX, 2GB RAM, 2.6 GHz Intel Pentium Dual Core CPU, 320 GB Hard Drive, 12' VGA touchscreen monitor, 3D mouse
My Worklog : http://www.mp3car.com/vbulletin/work...avalanche.html
Just fixed the images . Hope this will get me some replies
you cannot link pics from geocities directly into the posts. you must make a hyperlink so that we can travel to the geocities website and see it there. If lots of people look at it you will exceed your bandwidth limits so you should try and find someone to host it for you or something.
HELP please I have fixed the problems with images. Check it out and tell me what you think
Im having this same problem, any suggestions?
You should try to download updated drivers from the manufacturer's website. Actually I solved my problem by installing drivers from another CD that came with a second motherboard I ordered some six moths after I got the first one. Hope this helps.
Specifically which driver did u get or are using, c/b every driver i have tried so far causes me to get a no vga signal once i reboot.
when you go to "device manager" open display adpters and then driver details..... do you see the files in the system 32 folder???
