Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Auto reverse camera
  1. #21
    Maximum Bitrate Mad Ad's Avatar
    Oct 2004
    Hertfordshire UK
    que? engrish preese?
  2. #22
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Quote Originally Posted by cbergeron
    Ahh, I see - because the liliput needs 2 pulses.
    exactly.
    The lilliput needs the AV/PC button pushed once to switch to V1 when you put it in reverse and then it needs two more button presses to get back to VGA
  3. #23
    Variable Bitrate SickVette's Avatar
    May 2005
    Wesley Chapel, Fl
    Quote Originally Posted by eCarô
    I actually don't have a cam yet. But something like this is probably what I'll use. It will fit in the lens for my third brakelight. Just need to drill a hole in the red brake lens, and glue in a clear piece.
    In case you do not already know this camera is horrible to use in the car. I have one in the third brake light of my vette. The picture is ok at best but within 2 minutes of the sun being on it the screen white washes. I know a couple of other people that have used the same camera with the same results. White wash is a common problem with cameras especially cheap ones. I have a new camera that will not fit in the brake light but should not white wash. I have not had a chance to install it yet.
  4. #24
    Feb 2006
    I was putting together a parts list for this thing.
    http://www.freewebs.com/billymcbunter/
    Parts List
    PIC16F84
    Resistors: 100K, 2K, 3K
    Caps: 2->100pF, 3.3mF electrolytic
    1N414B
    1N4148
    BC549
    LM7805
    Relays: 2->5/6v
    Is there any substitution I can make for the 1N414B? It is really hard to find. The only places that have them (that I have found) take bulk orders only. In fact, I can't find the BC549 either. Any ideas?
  5. #25
    Feb 2006
    Would this work with a Xenarc?
    Just curious as I am about to instal my Carputer and plan to add a Camera in the future. Also, would it be possible to get a pre-programmed pic for those that do not have a PIC programmer?
    Best regards,
    Marc
  6. #26
    Variable Bitrate ramy_zohair's Avatar
    Sharjah, Emirates
    Quote Originally Posted by thrmaln
    Best regards,
    Marc
    Xenarc has the auto switch feature built in (on the AV2 line), so you don't need one.
    Final Touches
    Car: 2002 Mitsubishi Magna EI
    CarPC: SP13000, M2-ATX, 512 MB RAM, 120 GB 2.5" HD, X-Fi Sound Card, Xenarc 700TSV, Garmin 18 USB.
    Audio: 2X15" Rockford Punch Z, 1 Rockford Punch 2-ch Amp, 1 Soundstream Lil Wonder II 4-ch Amp
  7. #27
    Sharjah, Emirates
    What diode are you people using with the relay??
    Final Touches
  8. #28
    Feb 2006
    Quote Originally Posted by ramy_zohair
    I ended up ordering a relay with the diode built in. I think the 1N414B is a typo and should actually be a 1N4148. Not only that, the first relay really should be a 12V relay since it is taking a 12V signal to switch it. I am still in the process of building this thing. I have had immense problems but then I don't know much about electronics so I have been having to feel my way through it. I was also told the transistor (Q1) should be changed to a common emitter configuration rather than an emitter follower configuration. I didn't get it working either way but I may have been struggling with other issues.
    Has anyone ever succesfully built one of these? If you have and are willing to offer advice please PM me. I have about 16hrs spent on this with nothing to show for it yet (except a better understanding of things like, PICs, PIC programming, 7805 voltage regulators, transistors and such.)
    Edit: I also replaced the BC549 with a more commonly found one. BC547B.
    And I replaced the stabalizing caps with .22uF and .1uF
  9. #29
    Oct 2008
    i know how to get to view the reversing image,for i was in this area for years
    Quote Originally Posted by Tha Hombre View Post
    I'm going to be using (as soon as i get my Opus) a 7" Lilliput touchscreen with a weatherproof camera for reversing. I know the lilliput has a plug directly for the use of a camera. My question is this... how can i get to view the reverse camera as soon as i put the car in reverse??
    Is there no other option other than pressing a button on the screen to switch modes?
    Hi,my buddy,if you wanna to know more reversing cameras and monitors,i can help you a lot,please don't hesitate to send me e-mail for more catalogue and price list,my address is:[email protected]
    Best Regards,
    Yours' Truly,
    Eric Sun
  1. camera question....
    By Tripp in forum General Hardware Discussion
    Last Post: 04-16-2005, 01:49 PM
  2. Best DVD / camera software?
    By Tha Hombre in forum Software & Software Development
    Last Post: 02-06-2004, 10:03 PM
  3. Software for rearview/backup camera?
    By nxt125 in forum Software & Software Development
    Last Post: 07-21-2003, 07:34 PM
  4. Reversing camera
    By hapination in forum LCD/Display
    Last Post: 05-20-2003, 03:48 AM
  5. Have video camera for rear view - which program?
    Last Post: 08-15-2002, 12:25 AM
