Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Auto reverse camera
    Jan 2004
    Auto reverse camera
    I'm going to be using (as soon as i get my Opus) a 7" Lilliput touchscreen with a weatherproof camera for reversing. I know the lilliput has a plug directly for the use of a camera. My question is this... how can i get to view the reverse camera as soon as i put the car in reverse??
    Is there no other option other than pressing a button on the screen to switch modes?
    Maximum Bitrate eCar™'s Avatar
    May 2003
    SE Michigan
    Don't know exactly how the Lilli switches to A/V input, but I just worked out the same thing using a Cheese Box. I used that because my LCD controller is VGA in only. The Cheese Box converts the A/V signal to VGA.
    It was very simple because the button that switches from VGA to A/V input is the latching type. Meaning that when you press the button, it latches two contacts together, and displays the A/V input on the monitor. When you press the button again, it unlatches the contacts, and VGA signal is passed thru.
    I took the switch off the Cheese Box. I connected two wires to where the switch used to be, and ran them to a relay. The relay is triggered by the reverse lights on the car, so when you are in reverse, the contacts are made at the Cheese Box.
    I added a 3 position switch to allow for; A) Relay gets trigger from reverse lights; B) Relay gets trigger from constant 12V (so I can turn camera on without being in reverse); and C) No signal to relay (so I can be in reverse without the camera being on).
    I suspect the Lilli changes from one input to the other by pressing and releasing a button. Then you'd have to press and release again to get back to the other input. Is this the way it works?
    Low Bitrate doig's Avatar
    Apr 2003
    Melbourne, Australia
    What camera did you end up using out of interest?
    May 2003
    SE Michigan
    I actually don't have a cam yet. But something like this is probably what I'll use. It will fit in the lens for my third brakelight. Just need to drill a hole in the red brake lens, and glue in a clear piece.
    Feb 2004
    I would probably not recommend buying the cameras from DigitalWW until you find a decent way to enclose them. The plastic domes are not sturdy and break very easily. Its just my opinion, the cameras are great other then that.
    I bought this one. Its already in a solid water proof, metal enclosure.
    EDIT: It looks like your already taking care of the enclosure part, but in case you weren't.
    May 2003
    SE Michigan
    It will be inside my brake light. As protected as the bulbs in there. Should be fine.
    Jun 2003
    Memphis - TN
    Quote Originally Posted by King_Aero
    I bought the same camera, hopefully it will be a good one. I was debating on the IR cams, but went ahead w/ this one.
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    Aug 2003
    Orange, NJ
    Hey Ecar I have the infrared version of that camera though I did not buy it from digitalww. I am having a problems because when I connect it to my monitors I do not get any video on the lilliput 7' TS but I do get an image on my Jensen monitors in the headrest. I am stuck right now thinking of how to get this to work
    2002 Chevrolet Avalanche
    Zotac NForce 610i ITX, 2GB RAM, 2.6 GHz Intel Pentium Dual Core CPU, 320 GB Hard Drive, 12' VGA touchscreen monitor, 3D mouse
    My Worklog : http://www.mp3car.com/vbulletin/work...avalanche.html
    May 2003
    SE Michigan
    Quote Originally Posted by Dluvr22
    Are you connecting the camera directly to the Lilli?
    Can you connect something else to the Lilli to see that it's working?
    Constant Bitrate Sway's Avatar
    Dec 2003
    Muncie, Indiana
    just a suggestion but you might want to look into a $20 2.5 LCD Screen Controllers for XBox and use that as a rear view screen as someone suggested in another thread
    http://www.compusa.com/products/prod...647&pfp=BROWSE
  1. camera question....
    By Tripp in forum General Hardware Discussion
    Last Post: 04-16-2005, 01:49 PM
  2. Best DVD / camera software?
    By Tha Hombre in forum Software & Software Development
    Last Post: 02-06-2004, 10:03 PM
  3. Software for rearview/backup camera?
    By nxt125 in forum Software & Software Development
    Last Post: 07-21-2003, 07:34 PM
  4. Reversing camera
    By hapination in forum LCD/Display
    Last Post: 05-20-2003, 03:48 AM
  5. Have video camera for rear view - which program?
    Last Post: 08-15-2002, 12:25 AM
