Results 1 to 10 of 14
Thread: Has anyone bought this?
    Newbie milleda31's Avatar
    Mar 2004
    Vancouver, WA.
    Looks like a good deal...
    http://store.yahoo.com/ituner/carkit.html
    P.S. I would like to speak to anyone who has installed a carputer in a diesel vehicle. What concerns regarding key on wait for glow plug warm up...etc.
    Thanks in advance.
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    I have installed a carputer in a Vauxhall Corsa 1.5 Turbo Diesel. What are your concerns regarding glow plug warm up all about? I don't think it changes much as far as a carputer installation goes.
    Mar 2004
    Vancouver, WA.
    Quote Originally Posted by Rob Withey
    Well, my concern is that when I turn on key to acc position to warm up glow plug, PC will start to boot. When glow plug is warm and I turn the key to crank I believe it will kill the power to the PC momentarily. On my Kenwood head unit it does this. Basically it causes the booting process to interrupt.
    http://www.kenwoodusa.com/product/pr...productId=2375
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    Exclamation
    Quote Originally Posted by milleda31
    It won't cause the PC to reboot if you have a good power supply.
    And the power supply that comes as part of that kit won't be good for what you want. Really, the main option is an Opus, or something like a Sproggy if you feel like soldering it all yourself.
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Apr 2000
    Bedfordshire, UK
    Don't have that problem with mine. Machine survives cranking, glow plug heating, shutting down, cranking again, whatever... But then my power solution is a little unique. I have a custom ISR based power supply, remote power on signal from hacked headunit, the main power line to PC is always live, even when the key is out.
    Constant Bitrate bridqer's Avatar
    Nov 2003
    Maryland/Arizona
    I have also been researching this, I ended up calling opus solutions and asked them about diesel setups and they said it would work fine. I will know for sure when I build my setup in May.
    '99 F-350 Crew 7.3L~'02 F-350 Crew 7.3L~ '04 Dakota SLT+ 4.7L
    MII12000opus120~MII12000opus120~MII10000opus150
    NA~Senao dual 7.4 ant~Orinoco Gold
    Pioneer~Pioneer~PG Octane-R R5.1MT
    Xenarc, Rikaline6010, Garmin OEM16 HVS, CoPilot10
    Mar 2004
    Vancouver, WA.
    Thumbs up Made the plunge
    OK, bought this...
    http://store.ituner.com/ituner/carkit.html
    And this...
    http://www.morexintl.com/Morex%203688.htm (in black)
    What else do I need to get up and running...
    HDD
    CD/DVD drive
    Memory???
    OS
    Nov 2003
    You need a power supply that will work. Like the OPUS...
    OK, bought this...
    And this...
    HDD
    CD/DVD drive
    Memory???
    OS
    Mar 2004
    Vancouver, WA.
    Quote Originally Posted by Izik
    The power supply that comes with the kit wont?
    Maximum Bitrate brrman's Avatar
    Aug 2003
    Indianapolis, IN USA
    it will not survive crank
    Car: 2000 Audi A4 Avant 1.8t
    Carputer 2.0: removed. Back to stock.
  1. Replies: 9
    Last Post: 11-07-2003, 03:46 AM
  2. Replies: 3
    Last Post: 11-04-2002, 06:18 AM
  3. bought a 160W JENSEN inverter... should i keep it?
    By nadir_s in forum Power Supplies
    Last Post: 11-03-2002, 02:50 AM
  4. Bought a house (That didn't have cable)
    By PatO in forum Off Topic
    Last Post: 05-08-2002, 08:19 PM
  5. I bought an i-opener
    By crazyshaxs in forum General Hardware Discussion
    Last Post: 12-21-2000, 05:13 PM
