The lcd ( based on your 3 wire description) I assume is character ( not VGA ).
They typically use LED's as a backlight, they have an extreemly small current requirement, using the serial cable should not be a problem.
Everything else is also low voltage, and you will not have anny problems runing that over cat 5
LinkBack URL
About LinkBacks
