Results 1 to 5 of 5
Thread: Volume regulator question
    zvi
    zvi is offline
    Constant Bitrate zvi's Avatar
    Jan 2004
    Tbilisi, Georgia
    will it work, if i put volume regulator between PC and AMP? just a regular variable resistor (one per channel - I have 2 channels). will it affect on quality of the sound, or will it work at all?
    '93 Opel Vectra A with Custom Dash with 7" lilliput
    VoomPC/M1-ATX/M10K/256 RAM/20GB 2,5' HDD/Gemtek USB Radio/WinLite/RoadRunner
    http://zvi.home.ge/pics/?dir=vextra
    Feb 2004
    Elmira NY
    it will work.. but hurt quality. make sure the resistor oms isnt to high or you wont get sound out.. .
    im trying to make a 4 chanel volum control. useing one pot and 4 op amps.. havent got all the detals worked out yet
    zvi
    zvi is offline
    Jan 2004
    Tbilisi, Georgia
    how should I calculate how many ohms resistor should I have? in order to have the whole volume range (from 0% to 100%) spread to the whole spin range of the regulator
    Constant Bitrate P4_2.66GHz's Avatar
    Feb 2004
    Quote Originally Posted by zvi
    The way sound control resistors work is one end is connected to the ground, other to the signal and the mid-point is your output.
    Feb 2004
    Elmira NY
    you'v gota find out what V out put you have to get the right ohm or you'll have to big or no dead spot
  1. MP3 Volume Normalization
    By eCar™ in forum General MP3Car Discussion
    Last Post: 01-12-2005, 01:09 PM
  2. Replies: 11
    Last Post: 02-11-2004, 11:59 AM
  3. Replies: 6
    Last Post: 11-12-2003, 10:57 PM
  4. USB Sound Card with ASIO driver and volume control
    By tbdombrosky in forum General Hardware Discussion
    Last Post: 02-04-2003, 12:00 AM
  5. The volume question: MASTER vs. WAVE
    By tbdombrosky in forum Software & Software Development
    Last Post: 07-19-2002, 03:59 AM
