Results 1 to 10 of 10
Thread: Micro ATX Oprions
    Mar 2004
    Oshawa, Ontario, Canada
    Micro ATX case options
    Hi folks,
    I'm in the planning stages at the moment but hopefully someone here has seen something similar to what I'm looking for.
    I've thought lots about the EPIA but decided that an undervolted/underclocked Celeron on a micro-atx board would be best. So, I'm looking for the ideal micro-atx case.
    Casetronics makes one that is pretty small but it still has room for a floppy and a slim dvd drive, neither of which I need room for inside the case. Obviously, I don't want/need a floppy drive and I intend to use an external usb 2.0 dvd drive, so I don't need room for that in the case either.
    Basically, I'm looking for a case that will hold the following:
    - micro-atx form factor board w/celeron and heatsink/fan
    - opus 150W ps
    - one 2.5 or 3.5-inch hard disk
    - maybe one pci slot, but not really needed.
    --> don't want the wasted space for the floppy and 5.25-inch or slim dvd drive.
    Has anyone seen such a case? Has anyone seen a similar home-made unit? Basically, something to hold just the bare-essentials and nothing more.
    I appreciate the feedback. Thanks!
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    I'm replacing my EPIA with a microATX and 2.0 GHz Celeron, also. I have this case ordered and on the way. If the Opus 150w is SFX form factor as advertised, it should fit right in (there is some controversy on this - read here).
    Otherwise, the CS-4117 is small, lightweight aluminum (for good cooling) and will fit one full size PCI card.
    Apr 2003
    Quote Originally Posted by wi77iam
    I am also looking for a slim mATX case. I did a quick check on the mounting holes in the CS-4117 for the PSU based on the photos and it appears that the Opus 150W will NOT fit in the CS-4117. The dimensions of the Opus 150 are 125 x 100 x 63.5 (DxWxH) and it has mounting holes on the "long" (125 x 63.5) side as well as the "short" (100 x 63.5) sides. The SFX spec calls for 3 mounting holes - 2 holes along the height spaced 51.5mm apart and 1 hole along either the length (125mm) spaced 113mm from the centreline of the other 2 holes, or along the width (100mm) spaced 88mm from the centreline of the other 2 holes.
    The mounting holes from the CS-4117 are 43mm and 72mm respectively which is definitely out of the SFX spec. Also, the height of the CS-4117 is 90mm - the minimum height required to accomodate a SFX PSU is slightly over 100mm unless the PSU is mounted on its side.
    cdm
    cdm is offline
    Nov 2003
    atlanta ga
    mounting holes are your least of issues. a drill, some drilling, and you have custom mount holes. and then there is always the option of removing the PS from its casing, allowing you squeeze it just about anywhere. \
    right now actually i am going to mount the mini atx on the back of the back seat in the trunk, no case. don't ask..
    Mar 2004
    I found this today, micro atx case 13.77"x13.77"x5.31"
    http://www.amamax.com/pomaxc37simi1.html
    click small pic for larger one. I can't find much info on it.
    Mar 2004
    Thanks for the feedback guys. Other than the CS-4117 mentioned in this thread, I haven't seen anything else I like. I suppose it makes sense though... why would a case manufacturer make a box with no provisions for external 3.5 and 5.25-inch drives, other than to satisfy the carpc hobbiests
    I've changed my mind a bit about the hardware. I'm still sticking with the micro-atx form factor but I'm going to go with:
    - AMD Athlon XP-M (mobile) 2500+
    - Biostar M7NCG 400 (mATX, nForce2 IGP / MCP)
    The XP-M runs with 1.45V and the Biostar board can undervolt it to 1.3V for even lower power consumption. I'm also planning to underclock the chip a bit to further conserve power and reduce heat.
    So far, I think this Biostar board is the only mATX board (Intel or AMD) that can undervolt. Also, the XP-M is completely clock-unlocked so there's lots of options for undervolting/underclocking to reduce power consumption.
    I hope this proves to be a good solution!
    Sorry, got a bit side-tracked here. If anyone finds some more interesting mATX case solutions, please post them here!!!
    Thanks.
    Dec 2003
    Dec 2003
    and this one:
    http://www.newegg.com/app/ViewProduc...pa=0&section=3
    this is the one i'm most looking at
    Low Bitrate frenchnew's Avatar
    Mar 2004
    Canada
    How about mounting the PSU Externally?
    If this could be an option for you, then look at Biostar Ideq 200N.
    Just ordered such a beast for my own car setup, with the same Athlon XP-M as yours.
    regards
    frenchnew
    Quote Originally Posted by Darren
    Thanks.
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    My suggestion to you for your external CD/DVD is to go with Firewire and save your uSB bandwidth for all of the other devices that you WILL end up adding
    My 2 cents
  1. Micro ATX Athenatech case
    By Providence in forum General Hardware Discussion
    Last Post: 06-29-2005, 01:29 AM
  2. WTB: micro atx socket 370
    By Blop in forum Classified Archive
    Last Post: 02-23-2004, 03:21 AM
  3. Cheap micro ATX board at compgeeks.com
    By phat_bastard in forum General Hardware Discussion
    Last Post: 02-03-2003, 08:27 PM
  4. Micro ATX DC-DC PSU
    By y0manda in forum Power Supplies
    Last Post: 05-06-2002, 10:32 AM
  5. micro / mini atx system w/ LCD and all the goodies
    By gizmomkr in forum Classified Archive
    Last Post: 05-09-2001, 04:08 PM
