Results 1 to 6 of 6
Thread: Matrix Orbital Com Port Problem
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Angry Matrix Orbital Com Port Problem
    I've had a Matrix Orbital 40x4 LCD for over a year now and boy, does it work great! 'Been through 1-1/2 cold Minnesota winters, even.
    The other day, I was redoing my software and kicked up the serial port baud rate to support some fast graphics on the display. Everything I've seen since is garbled text...
    (few days out of warranty, no less)
    To add to the frustration, my display just happened to be the one model that didn't include a #$*(% hardware reset jumper! At least, I haven't found it yet in any manual.
    Anyone have any ideas? I'm thinking a big magnet might do the trick! He He, Anyone want to buy an LCD? I'll give you a good deal...
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Cool
    Several things might erase it. Try at your own risk. I doubt a magnet will have any effect. There may be a small battery that can be removed for a few minutes. There also might be a large value capacitor (several Farads!) that can be shorted (through a resistor) for a while to reset the circuit. Static electricity may work, but will probably damage other parts of the circuit. You might just want to contact the manufacturer as there is probably a very simple way to do this.
    Aaron Cake
    Player: Cyrix 200, 32MB RAM, 10.2Gig Quantum HD, Onboard EtherNet/Sound/Video, Custom Lexan Case, Arise DC-DC, Win95 Kernal w/Custom Player
    Car: '86 Mazda RX-7 w/Basic Performance Upgrades
    Aug 1999
    Yorba Linda, CA
    Post
    A magnet won't work since the LCD most likely uses flash memory for storage. And NEVER assume static electricity will do anything to your electronics other than fry them and render them useless. Always make sure you are grounded when you work with electronic devices. Static electricity is just about the worst thing you can do to your LCD.
    Contact Matrix Orbital -- I'm sure they have a reset procedure you can use to get your LCD back to normal.
    --Jason
    http://www.m2pc.com
    Jason Johnson
    Yorba Linda, California
    http://www.m2pc.com
    MPC Phase IV - *** PENDING ***
    Nov 2000
    Ottawa, ON, CA
    Post
    Ouch .. yup, static will do it for you .. but you wont likely be able to re-set any values simply because the micro. will be fried!
    What is the part number for the controller chip? Often you can re-set them by supplying Vcc to a RST pin.
    -James-
    Tech tips and more - http://www.techguys.ca
    *NIX command for today: rm -rf /bin/laden
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Post
    There is a GPO (general purpose output) jumper that is evidently supposed to reset the baud rate, but it doesn't seem to do anything. (I heard that from the place I bought it from)
    I've sent several E-mails to Matrix and haven't received a reply yet.
    The controller is a PIC16C67. I've been looking around for some sort of way to clear its memory, but haven't found anything yet. Seems fairly common, anyone have an idea?
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Post
    Well I'll be darned.
    I just happened to wander across a place that sells these displays. They had a PDF manual from Matrix that out of the blue, said to connect jumpers 5 & 6 of the keypad input!
    Boy, talk about messed up documentation!
