Results 1 to 10 of 10
Thread: Sound
    Mar 2004
    Sound
    How should I hook up my sound to my car speakers?
    Whats a cheap maybe FM Audio Transmitor or how should I do it?
    zvi
    zvi is offline
    Constant Bitrate zvi's Avatar
    Jan 2004
    Tbilisi, Georgia
    '93 Opel Vectra A with Custom Dash with 7" lilliput
    VoomPC/M1-ATX/M10K/256 RAM/20GB 2,5' HDD/Gemtek USB Radio/WinLite/RoadRunner
    http://zvi.home.ge/pics/?dir=vextra
    Mar 2004
    would a FM modulator work bad?
    Maximum Bitrate sfay93's Avatar
    Feb 2004
    Omaha, NE
    There are a few questions you need to answer before your question can be answered. Factory or aftermarket stereo in your car right now? Do you have an aux or cd changer input on your stereo? How much do you want to spend?
    Mar 2004
    i have a JVC aftermarket deck. It has AUX and I have a CD Changer in my trunk.
    Mar 2004
    Low Bitrate frenchnew's Avatar
    Mar 2004
    Canada
    Quote Originally Posted by hoodlum
    It would be best to use the auxiliary input on your deck if you are after sound quality.
    An FM Modulator is not even equivalent in quality to a strong FM radio station. It is mean't as a quick fix when you do not have AUX input available or you are on travel with a rental car and want to use your MP3 player with the car's radio.
    If you travel a bit, FM Modulators are prone to adjacents Station interferences and sometimes finding a wide enough gap between Station is a major undertaking if you do not want interference signals coming in.
    Best regards
    frenchnew
    Mar 2004
    Where would i would I be able to get a AUX wire to conect to my JVC deck and to the carputer?
    Mar 2004
    Canada
    Without knowing the type of conectors used, may I suggest the local JVC dealer unless your deck is equipped with RCA on the AUX input, then it's only a matter of getting a cable long enough with 1/8" stereo plug at one end and 2 RCA plugs at the other end.
    Feb 2004
    Omaha, NE
    Here is one place. Search and you will find more.
    http://www.pie.net/sec14sb4.htm
  1. Sound cards from incarpcs , sacrificing sound quality?
    By skinhead in forum General Hardware Discussion
    Last Post: 09-02-2004, 02:05 AM
  2. got sound?
    By masch in forum Newbie
    Last Post: 11-17-2003, 09:01 AM
  3. hissing sound
    By maxima13 in forum General Hardware Discussion
    Last Post: 04-30-2002, 10:28 PM
  4. Analogue sound and usb sound, at the same time?
    By MikeHunt79 in forum General Hardware Discussion
    Last Post: 03-27-2002, 07:30 AM
  5. Need advice on which sound card to use
    By mtmsol in forum General Hardware Discussion
    Last Post: 06-22-2001, 12:39 PM
