Results 1 to 9 of 9
Thread: Temparature displays
    Maximum Bitrate SAScooby's Avatar
    Feb 2004
    Johannesburg, South Africa
    Hi There
    Has any one or does any one have knowledge on how to get the ambient temparature and perhaps internal cabin temparature displayed on the carputer screen as a seperate application ? or maybe even visible like the time in media car or media engine ?
    thanks for the response
    Constant Bitrate Aftaab001's Avatar
    Mar 2004
    Kent, UK
    have you tried the matrix orbital displays? it's an external serial/usb LCD it has temperature probes. www.matrixorbital.com. Plugs in pc then program it to display the temp with the help of the sensor. That's what i've done, didn't intergrate it with the mediacar / media engine interface.
    Maximum Bitrate jusatry's Avatar
    Nov 2003
    Quote Originally Posted by Aftaab001
    Which model do you use? there are TONS on thier site.
    Nov 2003
    Seattle, WA, USA
    To get the temperature you can use this kit. It sends data to the serial port, and also gets power from there.
    http://www.electronics123.com/amazon/datasheet/k145.pdf
    Order on this page (CPS145 one sensor included)
    http://www.electronics123.com/amazon...gue/c3-3-2.htm
    Extra sensors (supports up to four per board)
    DS1820, order on same page.
    I have ordered it, but not yet installed/written software for it.
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Go here
    scroll down to
    "Use PC joystick port to measure temperature and light levels"
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Newbie BigRedBee's Avatar
    Jan 2004
    PDX
    I've got the hardware that NewTechFool describes. I'm using it to run a weather station. I've got multiple sensors (one inside, one outside) daisy chained to a long piece of CAT5, works great! You can even get humidity and barometric pressure sensors. Hardware is relatively simple, and tmp ensors are cheap. (I think they're around $3 each).
    VIA EPIA M10000 | 7" Lilliput Touch VGA | PW70 | 256 Meg RAM | 20 Gig 2.5" drive
    Dual Battery with Optima Yellowtop | Hellroaring Battery Isolater
    ICOM 2720A| Delorme Earthmate GPS | Tiny Track APRS
    Survives Crank
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    Mar 2004
    Kent, UK
    Matrix Orbital MX 212USB and the temp probe last item on this page. I've built it in where the original clock used to be ( centre of dashboard) looks absolutely gorgeous, displays mp3 artist/title for 10 seconds, temp for 5 secs, and clock for 20 secs. It carries on like this. It comes with the LCDC software and new plug-ins can be downloaded from net if needed ( e.g equalizer disp that works with winamp) It has a splash start up screen sayin my name etc) SORRY FOR THE LATE REPLY. WAS WATCHING THE A-TEAM!!! Also i bought it from http://www.kustompcs.co.uk/acatalog/...ay_Mounts.html
    Nov 2003
    Seattle, WA, USA
    Well I got the temperature module I mentioned in my post above. It is almost depressing how simple it is. Solder in a few components/wires, hook it up to your serial port, start HyperTerminal, and out comes a stream of temperatures.
    I am REALLY impressed with this kit.
  1. Replies: 21
    Last Post: 06-04-2005, 03:44 AM
  2. Apollo Displays
    By Apollo in forum LCD/Display
    Last Post: 10-16-2003, 09:48 AM
  3. 12 volt displays
    By welshman in forum LCD/Display
    Last Post: 08-01-2003, 08:54 AM
  4. Where do you find data sheets for TFT displays?
    By LCDcrazy in forum LCD/Display
    Last Post: 07-17-2001, 04:12 PM
  5. LCD displays -- what the best one out there
    By titanx in forum General Hardware Discussion
    Last Post: 09-17-1999, 10:40 AM
