Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: fans
    Low Bitrate LudeAtude's Avatar
    Jan 2004
    fans
    is it better to have them push air in or pull air out.
    • DS700YYV
    • Opus 150
    • XP Pro
    • Nehemia 10000
    • Indash Housing
    Maximum Bitrate eCar™'s Avatar
    May 2003
    SE Michigan
    No. It's better to have them pull air in, and push air out.
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    yes what he said.. if you only can use one.. i'd say pull the car out as close to your cpu as you can get
    '98 Explorer Sport
    80% done
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    Yup, by only having an exhaust fan, you are creating a lower pressure in the case than outside, thus running cooler. If the pressure was greater in the case than outside of it, then the inside of your case would turn into an oven.
    May 2003
    SE Michigan
    Quote Originally Posted by binary.h4x
    Can you explain this to us laymen?
    Aug 2003
    Lancaster, PA
    Personally I like it running pulling air in. Dust is less of an issue since you can put a filter on it that way. As long as you have a good airflow going, it won't make that much of a difference.
    Mar 2004
    San Francisco Bay Area
    ohh boy....the infamous "push/pull" question...
    I have seen this raised on several PC related forums. Some people have strong opinions both ways. Every time I have read about someone actually TESTING a theory, it seems to make little to no difference.
    I personally *believe* that actual airflow is more important than the push/pull question. Your typical PC case is far from airtight, so it's not going to develop much of a pressure differential, even IF you had several 120mm fans all pushing (or pulling) in the same direction.
    Some fans get better CFMs in a 'push' configuration, while others are better in a 'pull'. The manufacturer might be able to tell you if you knew where to look, but most likely you'll just have to try it out both ways and see.
    Of course, I'm assuming that you only want to have 1 or 2 fans (as in most car PC applications). It can get really complicated with more fans.
    If someone knows of any comprehensive testing with reasonable techniques and data, I'd love to see it!
    Dec 2003
    Canada
    Quote Originally Posted by LudeAtude
    Both.
    http://www.techtv.com/screensavers/m...505945,00.html
    May 2003
    SE Michigan
    Quote Originally Posted by eCar™
    Maybe it's better if they are sucking air out, or cramming air in. Or maybe blowing air thru.
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    what I do is always put 1 for in, 1 for out. but I've never really thought about air flow..etc.. so I could be way off.
    Mine needs to be updated.
  1. VW fans
    By Sh0cker in forum Off Topic
    Last Post: 11-12-2003, 07:13 PM
  2. FrodoPlayer - For you 800 x 480 fans 18 Oct
    By frodobaggins in forum Software & Software Development
    Last Post: 10-18-2003, 04:30 AM
  3. Those who run fans for cooling??
    By osirisdon in forum General Hardware Discussion
    Last Post: 06-12-2003, 09:30 AM
  4. Question for Telek, mailbox is full....
    By johnny010 in forum Power Supplies
    Last Post: 04-20-2003, 05:39 AM
  5. Any anime fans in the house?
    By ShinkunoNamida in forum Off Topic
    Last Post: 06-29-2002, 09:49 AM
