but ok..
non permanent way to hack the power of a laptop is with a docking station. and even then it might not work as desired.
if you use a laptop, mount it as one with a proper mount. so you dont have to buy the screen, input devices, cables...
no the lilliput and xenarc are not the same, even if they look close enough.
any inverter will technically work.
LinkBack URL
About LinkBacks
