Results 1 to 10 of 10
Thread: Mini-ITX vs. a desktop PC?
    Mar 2004
    Madison, NJ
    I've always purchased all my PC's prebuilt. For those of us who haven't built a PC before how much work is involved in using a Mini-ITX motherboard and custimizing it for carputer needs vs. using a desktop PC for the carputer?
    Feb 2004
    Michigan
    building a mini-itx system is exactly the same as building a regular system, but smaller. for the mini-itx, (and many new motherboards), just add memory, a hard drive, and power, and you are ready to go. if you are not familiar with building computers, you should look into it, it is pretty basic after some research, and can turn out very benificial. you will get a system for much less money than you would pay for a prebuilt system, it will have what you want and not a bunch of unneeded junk, it will be much smaller (if you go mini-itx) and you will learn what is in a computer, so you can better understand what is happening when somthing goes wrong. hope i helped, good luck.
    ray
    Feb 2004
    Quote Originally Posted by raypsaliga
    ray
    It's not always cheaper to build a prebuilt than it is to buy a dell....
    When their hot deals come around, they offered a 2.8ghz w/ 17"lcd not too long ago for 546 or some figure lower than that w/ 2 optical drives and 512mb ram (albeit it costed 150 to go from integrated graphics to a radeon 9800pro), but that's still as good as you could do if not better at the time.
    Feb 2004
    Michigan
    Quote Originally Posted by Mastermind
    i stand corrected.
    Jan 2004
    yea, you can actually buy pre-built systems for pretty cheap... but you wont get quality parts most of the time (Dell usually uses cheap parts)...
    and the avaliblity of pre-built mini-itx is not enormous... but i have seen them on ebay and mini-itx.com (european i believe).
    AT mobo
    Intel Pentium MMX 233mhz
    ESS Solo PCI soundcard
    Linksys NIC
    Irman
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    Plan on taking a pretty full day to uninstall all the bs spyware and bloatware on a dell, gateway, ect. I dont mind the hardware at all, but the software generally sucks for performance. Maybe I am biased, but I would say build your own and learn as you go. It is quite easy and very rewarding. Plus, a smaller form factor is harder to find by the big names. If your putting it in a car, you need to decide as much on room and heat as you do the dollar factor. The Itx form factor has those under control.
    Decided to try one of those $30 specials off ebay (update, looks like they are all gone now ) and it works well, I would say every bit as well as my Epia Classic did. Put in a stick of pc133, add a hard drive and a rom drive, and put it in a case. Its a full day thing for a newbie, but priceless for the experience. And CHEAP!!
    Good luck on whichever you decide-----Jeff
    2005 Ford Focus ST
    Dec 2003
    Portland, OR
    Its has an old desktop style panel, so it may be proprietary. Also it only takes up to a 2.0 so it is definately dated. I would keep looking myself. Check for a combo with processor, they are usually a better deal. It really depends on what you want from the system. If you can deal with the heat and space requirements, go for a full size computer, but if you are like many of us and dont have a lot of room (or money for the expensive power supplies!) go for a Itx setup. If you need one built for you, pm me, I can get you up and running very cheap and turn key if thats what you need.
    2005 Ford Focus ST
    cdm
    cdm is offline
    Nov 2003
    atlanta ga
    if you haven't built computers before (i use the plural for a reason too) you will run into the same problems that everyone else does.
    thing is, anything mini, is more expensive, more fragile, and typically more kinky, since you get into proprietary parts area.
    really, building a car pc can be as easy or as hard as you want it. ideally, you can get a cheap dell, wipe it out, make a clean install of whatever OS you desire and mount it in the trunk with cables running into the passenger cabin.
    perhaps thats the best approach for someone with little hands on experience.
    Mar 2004
    Madison, NJ
    I've been reading through the threads in this forum. There's some very good info here. Thanks for all the replies!
    I was lucky enough this morning to run into an old buddy of mine that I haven't seen in years. It turns out he does in-car entertainment systems for a local dealership. We talked a little about this project and he offered to give me a hand. I've already placed an order for a mobo and CPU along with an Opus. Is it really taking some people up to a month to get the Opus?
    Feb 2004
    Michigan
    i got mine from mp3car... shipped today. they are still in stock too... but they are $15 more than direct from opus.. id pay $15 dollars to have it in 3 days rather than 3 weeks
  1. Newbie asks ? Laptop based carputer vs desktop pc based carputer
    By SAScooby in forum General Hardware Discussion
    Last Post: 03-01-2004, 01:59 PM
  2. no mini itx between 1ghz eden and P4 2.4Ghz?!
    By Henke in forum General Hardware Discussion
    Last Post: 02-04-2004, 05:11 PM
  3. WTB: mini pc
    By dunkonu in forum Classified Archive
    Last Post: 12-24-2003, 03:43 PM
  4. mini itx and xp
    By oddcomp in forum General Hardware Discussion
    Last Post: 09-16-2002, 03:20 PM
  5. FS: Casio EM500 Pocket PC / 800mhz Desktop PC / Misc
    By gguy in forum Classified Archive
    Last Post: 10-07-2001, 08:00 PM
