I got an idea which i hope is original...
using the aux pin outs on my pioneer deck that are used to controll a cd changer, i want this to controll winamp. so i can skip ect using the standard buttons on my deck.. as i were playing a cd
how u might ask?
if the pins on the back controll a stacker then each button that is used by the stacker must be one of the PINS.. so left right 1, 2, 3ect would all have a pin and when pressed that pin would turn to a high state. and there would be one common ground.. and then 4 wires for the audio,
i know the 4 audio ones.. i just havent riped the deck out yet to find each button yet..
now.. there are heaps of winamp plug ins that let u controll winamp with a joystick..
using the pin outs on the deck and each pin that corisponds to a button hooked up to a relay which will connect the buttons on the joystick.. so the relay switch will take place of the buttons on the joystick.
using a 4 button joystick u can have 8 controlls.
what i dont know is....
how much load each pin on the deck can handel?
relays arnt much but will they be too much.. and how many volts they output.. im guessing 5-6v? to control some IC's?
and my main concern is. with the relays constantly clicking and clicking.. they might cause some interferance on the screen or in the
music?
Can u get solid state relays? or can someone tell me how to make this solid state somehow???
and last question (i promis) does anyone know the Vout of the joystick (com) port?
mick
