Results 1 to 6 of 6
Thread: USB 1.1 DVD - too crappy?
    Mar 2004
    pretty much every slim USB enclosure works with 1.1... so..
    is DVD performance gonna be ok on 1.1?
    on a side note... will i be able to install windows from a USB drive?
    Feb 2004
    San Francisco
    i don't know about the dvd being crappy, but I don't think you can do a fresh install off a usb drive. But if you already had a version of windows on the computer and you just wanted to upgrade, that would be possible. It would also be faster if you just copied the cd to your hard drive and then installed it.
    Mar 2004
    thats true... worst case scenario i copy xp cd to hard drive on my desktop.
    here's my problem.
    i only have USB 1.1.
    i have little/no $$
    i have a slim DVD.
    i have a 1/2" thick space for installing the DVD. drive will clear OK, but IDE adapters look like they're too thick. btw... any1 have one they could measure?
    if the adapter won't clear... i'm gonna go external. if i go external, i have to get an enclosure ($20) and either use existing 1.1 or upgrade to a 2.0 card. the 2.0 card brings 2 more problems. 1) clearance (pci overhead = 1") and 2)to clear, need $15 riser + $10 card.
    basically i'm looking for a DVD adapter thats less than the thickness of the drive itself (1/2").
    cost breakdown:
    dvd adapter (if it fits): <$20 (best)
    USB enclosure: $20
    USB 2.0 (if required): $15
    PCI Riser: $10.
    obviously i want either 1.1 or a slim (adjective) DVD adapter.
    Maximum Bitrate orangewhip's Avatar
    Apr 2001
    Surrey, B.C. Canada
    Installing Windows XP off of a USB DVD drive will work, I have done it. It all depends on the your motherboards BIOS settings. The Epia 10000M will boot and install off of a USB DVD drive.
    As far as DVD with USB 1.1, you can copy files and stuff over, but DVD playback will not be very good. The bandwidth of the video is just too much for 1.1 as far as I can tell with research...
    OrangeWhip? OrangeWhip? 3 OrangeWhips!!
    www.whipflash.com
    Finally a new Avatar!
    Maximum Bitrate jusatry's Avatar
    Nov 2003
    Quote Originally Posted by cybermob2
    here's my problem.
    i have little/no $$
    i have a slim DVD.
    cost breakdown:
    USB enclosure: $20
    PCI Riser: $10.
    If your slim drive will fit, so will the adaptor. My adaptor is exactly teh height of the DVD drive, it just makes it abou 1/2" deeper.
    Hope that helps.
    Constant Bitrate P4_2.66GHz's Avatar
    Feb 2004
    As said above, you can load OS from a USB device if MB's BIOS supports it.
    DVD playback on USB 1.1 is horrible.
  1. IDE to USB?? or USB slim slot load dvd drive
    By mercury in forum General Hardware Discussion
    Last Post: 04-07-2008, 11:50 AM
  2. Replies: 4
    Last Post: 04-06-2004, 09:52 AM
  3. Storix External USB 2.0 DVD Review
    By VWTronics in forum Input Devices
    Last Post: 09-27-2003, 06:20 PM
  4. Replies: 7
    Last Post: 09-01-2002, 09:25 AM
  5. USB DVD decoder
    By tyanni in forum General Hardware Discussion
    Last Post: 11-30-2001, 04:09 PM
