Results 1 to 10 of 12
Thread: thin flex IDE cables
    May 2003
    Does anyone know where i can get thin flex ide cables for ata66/100 drives? I would love to have access to these cables to use with my slim hdd and dvd drive. I was looking inside of a Dell Optiplex sx270 computer, and the slim hdd in that computer was using one of these cables. I NEED one for my custom car computer.
    Here is an example picture of what im talking about. Its not an IDE cable, but i want something similar in IDE form.
    Maximum Bitrate tom2112's Avatar
    Nov 2003
    Sharon, PA
    Bump!
    Me too. I wish I could buy sheets of the stuff, so I could cut off however many conductors I wanted and the length that I wanted. I could really use some for my in-dash monitor.
    So far:
    M10000 Nehemiah, 1Gb RAM, Opus 90w PS, Buffalo Tech WLI2-USB2-G54, 160 Gb HDD, GlobalSat BU-353 GPS, iGuidance, Zippy EL-610, Panasonic CW8123B Slim Slot CDRW/DVD, 10" Lilliput, Sony XA-300, Sony CDX-MP30 Head, OBD-II
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    Digi-key has the stuff. I don't know about sheets of the stuff, but you can get it with pretty many contacts.
    I'm thinking about replacing the round 'discrete' cable in my LCD with the stuff. Has anybody done this?
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    May 2003
    Whats the correct term/name for these type of cables? I dont even know what to search for.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Ribbon cables?
    TruckinMP3
    Read the FAQ!
    Mar 2004
    Flexible Printed Circuit Cable? (FPC)
    http://www.alancomputech.com/noteboo...ble--fpc-.html
    Nov 2003
    Sharon, PA
    There's a couple names for these things. Here's what I found out from a friend that makes PC components.
    www.digikey.com sells them (mostly in large quantity) and calls them Flat Flex cables.
    Parlex makes them. (http://www.parlex.com/laminate_cable.htm) and calls them laminated cable products.
    My problem is that I can't find anywhere that sells them one or two at a time. On digikey I found the cable that I want, but their minimum order for that part was 4000!! That would be one heck of a group buy!
    Does anyone know other places to get them? I've got an email in to Parlex sales, but they're not too helpful.
    So far:
    Nov 2003
    Sharon, PA
    Hey!! I found another section on www.digikey.com that calls them Flat Flex Jumpers. They sell them in small quanities (like 1!). So I am going to order 2 for my in-dash screens. (Part number HF20U-06-ND) should work. Maybe the longer one (P# HF20U-08-ND) at 8" will be better for me. So I'll order them both, at about $5 each, I'd rather have both than wait to reorder the right one.
    The only 40 wire (they call them positions) ones I could find were 6", 4", or 2" long. I don't know if that's what you're looking for or not. Here's some part numbers:
    HFF-40U-06-ND
    HFF-40U-02-ND
    HFF-40U-02-ND
    So far:
    May 2003
    hmm...i MIGHT be able to work with 6"...but finding an IDE connector to work with the cable is another problem
    Nov 2003
    Sharon, PA
    Bugster:
    I'm thinking your best bet would be to make a small breadboard. Mount the flat flex cable socket and an IDE 40 pin socket on the breadboard and wire the connections between them. That way you also have something firm (the breadboard) to bolt down to the case/frame/whatever.
    You can get the sockets from DigiKey too. Or if breadboards aren't your thing, you can get the flat flex cable with solder tab pins on each conductor. That way you could easily cut the end off of a normal IDE connector, and solder each wire to each conductor's pin. Then you have a flat flex cable with an 40 pin IDE connector on the end.
    Download section A of DigiKey's catalog.
    http://dkc1.digikey.com/us/PDF/T041/Section.html
    It's amazing! You can get just about any cable/connector that you can imagine. They've got everything from the 40 pin IDE headers to flat flex cables with ends already on them. The only limit is your wallet!
    So far:
  1. RE: Who Wants Custom Length 80 Pin IDE cables
    By 047025n in forum General Hardware Discussion
    Last Post: 02-23-2004, 03:25 PM
  2. How do I attach (2) ide cables together?
    By Scafremon in forum General Hardware Discussion
    Last Post: 01-03-2004, 08:21 PM
  3. Extending IDE cables?
    By JeremyD in forum General MP3Car Discussion
    Last Post: 06-27-2003, 02:32 AM
  4. 2m IDE Cables
    By samfox in forum Classified Archive
    Last Post: 04-09-2002, 03:57 PM
  5. Long IDE cables
    By dan0myte in forum General Hardware Discussion
    Last Post: 03-16-2001, 06:37 PM
