Results 1 to 10 of 17
Thread: Killed my on-board 250G shock laptop drive
    Low Bitrate spectrumzz's Avatar
    Sep 2003
    So I manged to kill a Fujistu MH2030AT laptop drive with fluid bearing. When I say "kill", I mean that I have managed to make the drive flake out under hard driving of my car... I thought with a shock rating of 250G (half-sine), the drive would be fine sitting on a sheet of air padding. I was wrong. The drive still works ok when it's sitting on a desk, but it has become very weak when the car is in motion.
    What I noticed is that what causes drive failure for me is very hard turns (ie. opposing the plane of head seeking), close to 1G while riding over a rough surface. I will probably change the next drive to be 90 degrees from the plane of the road, but I still don't see how that is going to stop the head from bouncing off the platter.
    Anyway, hopefully this will help people who have been asking "will my HD be ok in the my car" and the answer is: if you mount a shock-resistant 2.5 drive flat, with shock absorption, in a car with a rock hard suspension and good lateral grip, you WILL probably kill it.
    Next experiment: mounted vertical with no shock absorption at all.
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    This is the reason why I am going to use 256
    MB CompactFlash card instead of HDD - just for OS - and have all the media and hopefully nav. data loaded from CD or DVD media on demand.
    Constant Bitrate Magnezium's Avatar
    Oct 2003
    Los Angeles, CA
    Mpattonm, that's exactly what I'm doing, accept, the OS will run Disk On Chip so that the boot up time is almost nothing. But it will get all the settings (the written data) from a CP flash card, while all media will be on CD/DVD or other removable disks.
    Spectrum. I don't know too much about kenetics, momentum, and enursia, but try mounting the HDD 45 degrees instead of 90. I'd imagine (unless you live in areas where there are many pot holes) you would split the wear and tear on the drive 50% depending on accelloration and turning. Turning at 1G should be cut in half at 45 degrees. But I could be wrong. Anyone agree or disagree?
    Mg
    Just your friendly neighborhood computer specialist.
    2002 Pontiac Trans Am WS.6
    Silver/Black
    Looks like new... Wanna know why they call me "Crash"?
    May 2003
    Czech rep.
    Quote Originally Posted by Magnezium
    What size will you DOC have? And - what OS have you chosen? I am currently experimenting with WinME which I have stripped to 110 megs. 150 megs including MediaPlayer, DX9, BlueTooth stack and Mozilla.
    Oct 2003
    Los Angeles, CA
    I'm planning on using XPe. However, not sure. I know that with XPe, I can get the footprint down to about 30MB with my media program installed (Haven't named it yet.) However, the DOC will probably be 128MB just in case. I might end up installing some 3rd party software (I doubt it, but it's possible) so I want to keep my options open.
    I don't like WinME because it has problems, but if you're using a read-only disk, it's possible it will work just fine with out errors. It's the writing to the OS that screws it up so fast. XPe, is faster and a lot more stable. I recommend not using the Explorer Shell and use your media players executable for the shell. It will signifigantly help WinME, that is unless you use more than just one program.
    Mg.
    Silver/Black
    Sep 2003
    New York
    I drive the car pretty hard and take pretty tight turns at times, now I am worried about mounting the pc into the car now lol It appears there is really no consensus on how to mount these hard drives. I've used a laptop in the car many times, either left it on the floor or just in the seat and it still works fine. Been doing it for about a few months now and it is still ok.
    And this is in NYC with all the huge *** potholes all over the place.
    Mar 2004
    Mg.
    How do you obtain WinXPe? Also is there a good place to buy DOC and what would be a major difference between DOC and CF?
    Thanks.
    May 2002
    Mebbe you should change your driving habits to more sensible and "cool" ways
    I don't need no stinkin' startup-shutdown controller... That's what journalized filesystems are for...
    NavSys, the ultimate navigation app
    http://www.navsys.org/
    Sep 2000
    LA, CA, USA
    I ran an 800 MB flash drive for the last year but just a week ago it died. Too bad because it worked great until then. Be wary of the number of reads/writes to flash memory.
    Phoenix Az
    Talking
    Quote Originally Posted by az1324
    Well every drive works great. That is until it dies.
  1. Hard drive shock problems.
    By Mikesz in forum General Hardware Discussion
    Last Post: 03-21-2005, 03:37 PM
  2. laptop dvd drive
    By agent_86 in forum General Hardware Discussion
    Last Post: 10-30-2002, 06:15 PM
  3. laptop cd drive
    By smashr2k in forum Classified Archive
    Last Post: 10-02-2002, 10:42 PM
  4. External notebook hard drive help
    By mtmsol in forum General Hardware Discussion
    Last Post: 04-18-2002, 12:24 PM
  5. Any info on this laptop dvd drive
    By tapper1999 in forum General Hardware Discussion
    Last Post: 01-15-2002, 03:54 PM
