Results 1 to 7 of 7
Thread: Motherboard with P4 12V connector
    Constant Bitrate ashbosh's Avatar
    Mar 2004
    Question Motherboard with P4 12V connector
    Hello everybody,
    I'm thinking of using this motherboard which has this 12v 4 pin connector (indicated near the arrow in the picture). I want to use DC-DC psu. The question is whould the psu be able to handle to load on the 12V rail since the cpu is powered using this 12V connector? Isn't it true that the cpu is powered by 5V thru the ATX connctor?
    I really liked this board since it has everything I need. I just wanted to know whether should I go ahead and buy it. Thanks in advance.
    Maximum Bitrate eCar™'s Avatar
    May 2003
    SE Michigan
    The new ATX12V boards do use more juice from the 12V rail. But as long as you don't overload it, a regular ATX power supply (with an adpter to connect to the 4 pin 12V socket on the mobo) will be fine.
    Fortunately, we have the car's 12V power to run fans and other 12V accessories (that can deal with the voltage fluctuation), so keeping the load low on the 12v rail is not too diffucult.
    Variable Bitrate Banderon's Avatar
    Sep 2003
    NJ
    If anything, as always, you can just run two power supplies in parallel.
    Constant Bitrate P4_2.66GHz's Avatar
    Feb 2004
    You should have no problem running this board. Opus 150 DC-DC PS already has that connector. Be advised, the board is a 423 pin version. All new P4 CPUs are 478 pins.
    Mar 2004
    Its an Socket A board and I'm going to run Mobile AMD on it which is supposed to run 35W max. And with AMD Powernow I think I will be able to reduce the power consumption. Its also possible to undeclock the cpu, but I couldn't find suitable board which are small enough to suit my needs. If you know pls let me know.
    Thanks again.
    Feb 2004
    Quote Originally Posted by ashbosh
    Thanks again.
    I see. I figured you were going to put a P4 in it since the title had the P4 connector mentioned.
    Phoenix Az
    Quote Originally Posted by P4_2.66GHz
    Yeah. Its those little details that will get ya every time.
  1. 12 Volt 250W,ATX WITH P4 CONNECTOR
    By xtreamvette in forum Power Supplies
    Last Post: 03-10-2004, 01:29 AM
  2. look at this for a P4 case and motherboard and DVD-rom
    By bertybassett in forum General Hardware Discussion
    Last Post: 01-08-2004, 04:29 AM
  3. P4 power alternatives?
    By tejesh83 in forum Power Supplies
    Last Post: 06-24-2003, 11:47 AM
  4. Ultimate Car PC motherboard, P4 power, Firewire, USB2.0
    By cproaudio in forum General Hardware Discussion
    Last Post: 10-03-2002, 06:50 AM
  5. getting an odd motherboard to power on
    By karmann in forum Power Supplies
    Last Post: 11-28-2001, 06:27 PM
