if the subs are close to the case they might mess things up becasue of the magnetic field. i say if u can fit it all behind the screen do it makes averything look clean.
I have a used Casetronic mini ITX-2677R case that I am using for a Epia M10000. I need help deciding if I should keep the case or ditch it. I like the case alot but it won't fit where I planned to put it (glove box). Also the case is too big to house my Opus Power supply so I would have to mod it to get the power cables inside. I could do this and put the case in the trunk (will subs mess with this?) or I can ditch the case and put the computer behind the screen in the front. What do you all think?
2003 Audi A4 1.8t (Totaled, Project Canceled)
Spaceboy, I bought the same case. It fits perfectly under my passenger seat (which isn't heigh adjustable) in my 02 Impreza.
sub's won't do nothing to it unless the case is within 8 inches of the sub's magnet and you have over 500 watts going in to your sub's
Hum, ok I'll see if I can fit it. The only thing is that might seat's have a storage bin under them. Maybe I can remove it. Good idea though.Originally Posted by Almost a Ghost
Why not put it in the bin?Originally Posted by Spaceboy464
Edit: The computer, I mean.
Edit2: In the storage bin!!!![]()
The bin is too small. It holds 1 kilo...or so it says.Originally Posted by Laidback
