Results 1 to 10 of 19
Thread: What hardware is everyone using?
    hey all, im new to forum so if this is all off then srry
    anyway, when i look at cpus today, i dont see many that could be considered acceptable for a carputer. i believe some P4s suck over 80 watts, so you can see the problem. what i want to know is some common mobos and CPUs used by people who have already made their puters.
    thnx to everyone
    Nov 2003
    Olympia, WA
    Here's something that might help. I look at everyone's signatures as I go through the various posts. A lot of people have their specs listed. It helped me on where to start/look for hardware. Incidentally, I have:
    Epia 800
    20 gig laptop HD
    Slimline CD
    Low Bitrate TommieG's Avatar
    Mar 2004
    Norway
    Have a look at VIA's mini-ITX or nano-ITX motherboards/cpus.
    That's what most of th ppl here are using. They are very small sized and are using much less power than ATX/INTEL/AMD combos.
    By using the VIAs with half height/laptop drives, your whole setup will probably use less power than an P4 or AMD cpu alone.
    Tom
    VIA EPIA M9000/120 GB/Xenarc 700TSV/Opus 90W DC-DC
    Haicom GPS/3Com 11g Wi-Fi/D-Link BT
    WinXP/myHTPC/InfoMap Navigator Eu/PhoneControl w/T68i
    Blaupunkt HU & speakers/Velocity active subs/Alpine amps
    Progress: removed while waiting for nano-itx
    can the via eden_n play divx compressed video?
    FLAC Chairboy's Avatar
    Jan 2004
    Quote Originally Posted by Quazimodo
    The M6000 and the M10000 can, according to reviews, do that quite nicely.
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    look at signature...
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    Maximum Bitrate sfay93's Avatar
    Feb 2004
    Omaha, NE
    Quote Originally Posted by Defiler
    Ditto
    ATVMS.com
    defiller, how much watts does that system pull?
    actually, im going to ask a very nooooob question... what is the max amps one can pull from a battery safely (not an instant discharge ofcourse)
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    I run a P233MMX system, it runs off less than 30W all in. See sig for spec. See website for pictures.
    Rob
    Phoenix Az
    Since everyones needs are different going by what other people use is not a good idea. Your needs may be different than someone elses.
    What equipment you decide to go with will also determine what your power solution needs to be. Some people use Opus power supplies while others need inverters to power their computers. Decide what you want to the computer to do and then shop around like you would a desktop or laptop but remember that its going in a car so make sure you keep that in mind as well.
  1. need soft that rescans hardware after STD
    By felix99 in forum Software & Software Development
    Last Post: 04-09-2004, 11:14 AM
  2. Who has the slowest hardware
    By berniejr in forum General Hardware Discussion
    Last Post: 03-02-2004, 01:36 AM
  3. hardware woes - just venting!
    By magnetik in forum Off Topic
    Last Post: 05-21-2002, 04:31 AM
  4. WTB: Touch hardware + FS: Touch hardware :)
    By W6-Ryan in forum Classified Archive
    Last Post: 04-17-2002, 01:20 AM
  5. hardware volume control
    By ODYSSEY in forum General Hardware Discussion
    Last Post: 04-20-2001, 11:43 AM
