Results 1 to 10 of 16
Thread: Bootup - Which OS Question
    Apr 2002
    Houston, TX
    Not quite sure how to fix this, but when the comp boots up it come to a screen asking which operating system do you want to use.... Windows XP or Windows....
    A little history, the HD is a new Laptop drive that was formatted when I got it (off eBay) and it had the command.com (not usre about the .com, but you know the file... it has been a long time since I have messed with DOS)....
    I went and installed XP on the drive, and I had it convert the drive from FAT32 to NTFS, which I think left some sign of Windows on there (which actually was never installed) from that command.com file....
    Anynow in the C:\ directory the command.com file is no longer there.....
    Anybody know how I can get ride of that boot up question?
    Thanks in advance.
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by dug1967
    Thanks in advance.
    Edit C:\msdos.sys
    [Options]
    BootDelay=0
    BootMulti=0 < change to 0
    BootGUI=1
    Maximum Bitrate sfay93's Avatar
    Feb 2004
    Omaha, NE
    Probably need to edit c:\boot.ini to look like this:
    [boot loader]
    timeout=0
    default=signature(2cb92cb9)disk(0)rdisk(0)partitio n(1)\WINDOWS
    [operating systems]
    signature(2cb92cb9)disk(0)rdisk(0)partition(1)\WIN DOWS="Microsoft Windows XP Professional"
    /fastdetect
    Your's probably has 2 OS's listed there. Just delete the one that doesn't say partition(1).
    ATVMS.com
    Apr 2002
    Houston, TX
    Well thanks for the info guys, but unfortunately I don't have either of those files.... msdos.sys or boot.ini
    I searched the entire HD and neither is there....
    Confused....
    Jan 2004
    you might be able to alter this within bios, or atleast have it so it only gives you say 3 secs and then selects the os you want.
    Apr 2002
    Houston, TX
    I shall look, but I can't think of a place in the bios that would control something like this...
    By the by, the MB is a Via M10000....
    But I shall look.
    Oct 2003
    Madrid
    Confused....
    In Windows Explorer, click Tools > Folder Options > View and select 'Show Hidden Files and Folders'
    It's nothing to do with the bios.
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    Confused....
    Go to the "run" command and type the c:/boot.ini...worked for me when I tried it.
    2005 Ford Focus ST
    Mar 2004
    Lightbulb
    A suggestion:
    right click on My Computer
    select properties/advanced/startup and recovery/settings
    and then "edit startup files manually"
    OR (to explain why you can't find the files in question)
    In the Windows Explorer:
    select menu: tools/folder options/
    in the view tab, make sure that its letting you see hidden and system files.
    "show hidden files and folders"
    and
    uncheck "hide protected operating system files"
    Good luck!
    Apr 2002
    Houston, TX
    Quote Originally Posted by gospeed.racer
    That works Speed.... here is what I have in the file....
    [boot loader]
    timeout=30
    default=multi(0)disk(0)rdisk(0)partition(1)\WINDOW S
    [operating systems]
    multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Micro soft Windows XP Home Edition" /fastdetect
    C:\ = "Microsoft Windows"
    What should I change it to????
  1. The Os and The Car
    By SjLucky in forum Software & Software Development
    Last Post: 06-24-2004, 03:09 PM
  2. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 10:11 AM
  3. Geforce4 MX440 bootup question
    By Tony S in forum LCD/Display
    Last Post: 07-17-2003, 04:30 AM
  4. Finally settled for an OS. (question though)
    By churnopol in forum General MP3Car Discussion
    Last Post: 04-24-2003, 07:42 AM
  5. Which OS?
    By accord in forum Software & Software Development
    Last Post: 11-22-2001, 09:22 PM
