Results 1 to 10 of 19
Thread: shuttle PC
    Feb 2004
    melbourne
    shuttle PC
    how many people use shuttle pc's or are interested in them...
    for example, if i could get them cheaper than pretty much anywhere else would people be interested? comments please!
    Mar 2004
    I don't know how good they would be for a car, from what I read on other computer boards, they overheat horribly as is, without cars adding environmental quirks.
    Low Bitrate frenchnew's Avatar
    Mar 2004
    Canada
    I am going to use one myself, Not a Shuttle but Biostar Ideq 200N.
    I hope that by using the mobile version of AMD's XP-2500+ it should not be much of a concern for heat and with the added bonus that it uses less power (45 Watts for the mobile version compared to 68 Watts for the desktop version).
    The way I look at it, the Small Form Factor PC (AKA Shuttle types) come in a decent case with motherboard, all the ports you wished for and can be used in homes or car if you so desire. For me the upfront cost is not much different then going with Via's ITX solutions once you factor the cost of the case.
    Also, please note that I am going to install this in a Honda Odyssey which has plenty of room compared to a car.
    Best regards
    frenchnew
    Quote Originally Posted by arkadiyp
    Mar 2004
    Also I don't know about biostar, but shuttle I believe uses some weird proprietary motherboard, so forget about upgrading anything.
    Mar 2004
    Canada
    Smile
    Most of these shuttle type pc use proprietary Motherboards as you stated.
    But you can upgrade the graphic card (Some of them have the AGP slot) and some also have a PCI slot.
    Talking about the ugrade ability, what do you think can be upgraded on a Via Epia? beside having a PCI slot, they do not offer an AGP slot.
    So these 2 types are very similar as far as their upgrade ability with the exception that with the shuttle type you can upgrade the CPU if you did not opt for the fastest processor available, on the Epia those CPU are soldered.
    Also, for me in Canada, the shuttle form factor as another positive, cost.
    I have paid $340CDN for my Ideq200N (Case, Motherboard, PSU) while the Via Epia M10000 are $230CDN and the newer version -II is at $300 CDN.
    Add the cheapest case available and you tally up another $110CDN and I am not talking the best here as Casetronic's case hover around the $200 mark.
    Even thought the Epia is pretty decent for car computer uses, I wanted to keep my option open with more processing power.
    With that in mind, soe of the shuttle types are coming equipped with built-in Stereo FM Radio and TV-Tuners (Check out MSI Mega 180).
    Also, for the heat aspect, AMD processors systems are equipped with shutdown features should the system overheat (You configure the setpoint in the Bios).
    Best regards
    frenchnew
    Maximum Bitrate S4Per's Avatar
    Jan 2004
    Seattle, WA
    I use a Shuttle SB61G2. No complaints, but one thing to look out for: USB bus stays powered after shutdown. See my post today on how to solve that so you don't drain your battery.
    Feb 2000
    Rockford, IL (home), Southern IL (college)
    i have a Shuttle XPC sk41g in my car right now, i love it! well worth the money. i am using it with a power inverter - 150w, 1.6ghz AMD, 60gig hd, and slot load dvd.
    2004 F-150
    Shuttle XPC, 80gig HD, Wireless Internet, DVD
    "How piMP3d is your ride??"
    Maximum Bitrate Don 944 LA's Avatar
    May 2004
    San Diego / Los Angeles
    I'm going to be using one of these.
    Radio and CD player works even when PC is off.
    Relocate front panel to dash and put rest somewere else.
    found this.. take a look
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    ok don, we get it. you like the new MSI cube.
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    Total spent on wedding so far: $3885.79
    Thanks to everyone for your support.
    I'M DEBT FREE!!
    A Brit in Las Vegas
    I use a shuttle and it's fine - only problem is that it's too big for most vehicles but if you have the space then they seem fine. The only complaint is that I can't get the BIOS (on my SS40) to recognise the AMD 2600+ (it calls it a 2000) but as the speed is more than adequate I'm not too bothered.
    Also the onboard sound and video is perfectly adequate for a 7" touchscreen and car amplifier sound system.
    Steve
    RV : Samsung Q1 + Kyocera KR1 (EVDO) + GPS<br>
    Car: AMD 3000+ Book PC + Lilliput 8" Touch + 13" TFT
    Webmaster for the European Ford Scorpio Site
  1. PC audio too low
    By Alphared in forum General Hardware Discussion
    Last Post: 10-04-2008, 05:20 PM
  2. How2 control CarPC from key fob....
    By NotchbackVW in forum Power Supplies
    Last Post: 09-21-2007, 06:27 PM
  3. For Sale for all you aussies. Complete mp3 car pc
    By Holden__V8 in forum Classified Archive
    Last Post: 04-09-2005, 06:30 AM
  4. Shuttle PC with Opus PSU or not?
    By TargeT in forum General Hardware Discussion
    Last Post: 03-24-2004, 06:53 PM
  5. FS: Casio EM500 Pocket PC / 800mhz Desktop PC / Misc
    By gguy in forum Classified Archive
    Last Post: 10-07-2001, 09:00 PM
