Results 11 to 20 of 21
Thread: Looking for a web cam for rear veiw.
  1. #11
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Talking
    Quote Originally Posted by greaper007
    How do you mount the camera in the keyhole? Is there a guide for this?
    Step 1: Remove lock from keyhole.
    Step 2: Insert camera in keyhole, duct tape liberally
    Step 3: Wire camera
    Step 4: Enjoy.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
  2. #12
    Newbie cnugget23's Avatar
    DFW area (Plano, TX)
    King_Aero, Streetknight,
    I like the camera you guys have. Any suggestions on how to install/wire it so that the camera view comes on in the monitor when the reverse lights are activated?
  3. #13
    This might be what you are looking for :
    http://www.lashen.com/vendors/elyssa/pc_camera.asp
    One thing that you should look before buying a IR camera for night vision is the viewing distance.
    From what I've read, there's a number of factor you need to take into account that might affect the viewing distance of the camera, like the number of leds, the intensity of the leds...
    It seems that most IR camera offer short viewing distance at night, 10~30 meters. Those distance are fine for a home solution but not really usefull for a car where distance is what you would likely want to have as far as possible.
    So before buying one, I'd personnaly try to find a product that has a long range for the IR illumination.
  4. #14
    Variable Bitrate streetknight's Avatar
    Dec 2003
    i just leave mines on this way i can look at girls walking behind my car on redlights. becasue
  5. #15
    Variable Bitrate Banderon's Avatar
    Sep 2003
    NJ
    You can always buy more IR LEDs, and mount them liberaly in the lights on the rear of your vehicle.
  6. #16
    Maximum Bitrate TimmyM's Avatar
    Aug 2003
    Federal Way, WA
  7. #17
    Variable Bitrate Superduck's Avatar
    Oct 2003
    Vancouver BC
    Quote Originally Posted by mako
    I was thinking about going with IR as well. The only thing is, I can't think of a reason for having longer distance at night. You're already seeing more with a regular IR camera than you would with a rear-view mirror. Why would you have need to see really far in complete darkness, behind you? My back window is tinted dark, and aside from changing lanes and backing into parking spaces, I seldom use my rear view.
    I've also heard that headlights blind the IR cameras anyway.
    I'm not trying to shoot down the idea, since I'm planning on doing it too, but I'm just curious why I would need that kind of distance.
    Kris
  8. #18
    Probably why I was putting emphasis about having a longer viewing distance is because I'd set it up to have a camera where I can see farther ahead. And in my setup, it would be mounted upfront to see ahead of the road rather than for seeing in the back.
    But true, if it would only be used for reverse driving or a quick look in the back, distance might not play a big factor.
    I guess it goes to what extent you'd like to see in low-light condition.
    I remember an add from Cadillac (i think) where you had a Heads-up Display on the windshield for the nightvision while driving at night and you could see a deer on the road and the surronding road-forest where, with the headlights, you only could see a fraction of what was possible with the night vision.
    Basically, I always found the idea of seeing better at night really really cool.
  9. #19
    Apr 2003
    Cleveland Ohio
    I think the caddy used thermal imaging for this. Like the police use on helicopters at night. It picks up a heat signature, like the deer. I have to imagine this kind of setup would be ubber-expensive.
  10. #20
    Sep 2003
    NJ
    First of all, there've been a number of threads on this already.
    Second, to recap the other threads, the Caddy has an IR projector/detector in the grill which is how it gets its image. The HUD image is projected onto specialy coated windshield glass. It's all night-vision, just a lot more powerful than a few measly LEDs.
    Basically, the conclusion in the other threads was that it's too expensive to make a system like the Caddy's.. thought I'm sure some have tried and succeeded.
    As for using a screen to display the image, it'd distract you from the road more than help you.
  1. Min Requirements for a web cam
    By edie209 in forum Off Topic
    Last Post: 05-17-2001, 03:50 PM
