Ok.... so let's try again. Which EPIA Motherboard should I get? Is the MII 10000 the best?
Ok,
I'm just about to order an EPIA MII motherboard (probably the 1GHz as I can't find any where that has the 1.2GHz (mini-itx excluded).
My PSU is an OPUS 90W. I need:
- Small size
- Low power usage
- Low heat / low sensitivity to heat
- Good spec etc.
- Good price
So, please tell me what you think, and ASAP as I want to order this evening.
Andrew
06 Volvo XC90
Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
Car PC downloads: http://carpc.harteveldt.com/
06 Volvo XC90
if you need CF and PCMCIA built in then yes MII is the best. If you don't need those things than a cheaper M 1ghz is the best.Originally Posted by skippy76
Hope that helps.
That was my thinking, just wanted to get someone to tell me.. before I spent the $$$
06 Volvo XC90
Also for the same money you can go with athlon-M, a little more power requirements, but a lot more bang for the buck.
Ok, but which motherboard? I have a 90W OPUS. Where can I get it?
06 Volvo XC90
Athlon XP-M is about 34 watt, motherboard with everything onboard is 30 watt +HDD +optical you may actually run into problems, so on second thought I retract my Athlon XP-M idea. If you want to risk it I would go with www.newegg.com.Originally Posted by skippy76
Ok, the EPIA MII it is then.
06 Volvo XC90
