Results 1 to 3 of 3
Thread: "Fanless" Motherboards
    Mar 2002
    For the most part, probably just applies to the Epia's unless there are some other ones out there.... anyways, fanless is self explanatory. But just how far can you go with this? They say "passive cooling" in the docs, but can you seal this things (and a 5400RPM hard drive) in... say, a aluminum/steel case?
    Speed is not a big concern, just needs to run linux (cmdline mode) or stripped down Windows.
    Mar 2004
    Quote Originally Posted by PrimusSucks
    What do you mean seal?!? No vents at all? You better make a case into a heatsink then and make sure not to touch it.
    Mar 2002
    Pretty much sealed.... it's going to be the sister server to this, similiar design:
    http://www.geekmods.com/slimp3/images/front12.jpg
    Shoulda stated... does NOT need to be an Epia, or even a mini-itx. I have a little space to play with and underclocking is OK.
  1. UK supplier for XPC motherboards
    By daiwilliamsuk in forum General Hardware Discussion
    Last Post: 03-29-2004, 08:49 AM
  2. Anyone want Pentium 233 motherboards?
    By pigseye in forum Classified Archive
    Last Post: 01-29-2003, 12:50 PM
  3. Flex ATX motherboards?
    By zootjeff in forum General Hardware Discussion
    Last Post: 08-06-2001, 12:31 AM
  4. What motherboards are you using?
    By paris68 in forum General Hardware Discussion
    Last Post: 12-10-1999, 11:12 PM
  5. -12 on motherboards?
    By Fosgate in forum General Hardware Discussion
    Last Post: 11-09-1999, 06:10 PM
