Results 1 to 10 of 20
Thread: Using Cat-5 as Speaker Wiring ??
    Aug 2001
    South Africa
    Arrow Using Cat-5 as Speaker Wiring ??
    Hi, i hav hearda romour :
    that its posible 2 use cat-5 utp cable to run your speakers from the amp !
    ive got 2 competition 12" Lanzar subs ,
    havnt got any cables as yet .
    would it be beter 2 go the conventional speaker wire way , or does UTP hav any advantages ?
    If its 2 loud ur Old ,;-)
    Jul 2001
    Post
    I don't think cat-5 is heavy enough or should I say, able to handle the current needed by the speakers.. Go for the speaker cable..
    Mar 2001
    Cincinnati, Ohio
    Post
    cat-5 works great, its what I used. just double up the wires. And it cuts out high frequency whines since its twisted. I used it on my home stereo, and I noticed a huge inprovement. Oh, and I've even heard of Audiophiles using it in home built systems.
    Clarion 200watt head unit w/ Aux in.
    Kicker 800watt 4 channel amp
    In a 96 Grand Prix SE.
    Jul 2001
    Post
    Fine, you win, I wouldn't know...
    Aug 2001
    South Africa
    Arrow
    well , just tell me , the 2 12" im running r 450W RMS each , how should i set up the Cat-5 cabling ?
    i can get quite a bit of cat5...
    should i run double pair 2 each sub , or will 1 do (if this makes sense)
    shot 4 info ??
    Nov 2000
    Ottawa, ON, CA
    Post
    CAT5 UTP for speaker wire? OUCH.
    Bigger _IS_ better in this case (to a limit). The thinner (larger gague) the wire is, the greater the resistance, thus the greater the loss of signal strength.
    Go buy some decent 12-16 gague speaker wire! Especially if you are pushing 400+ W RMS !!
    -James-
    Tech tips and more - http://www.techguys.ca
    *NIX command for today: rm -rf /bin/laden
    Mar 2001
    Cincinnati, Ohio
    Post
    yeah, I only have two old 8"s on an old amp.
    moahdib's Avatar
    Jul 2000
    Post
    speaker wire is cheap... why would you want to use CAT5 for that?? I wanted to use cat5 for my line outputs from my head unit to the amps... running 3 sets of RCA's does not look pretty (front, rear, subwoofer)
    has anyone tried this ?
    [ 09-11-2001: Message edited by: moahdib ]
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
    Aug 2001
    Olympia, WA
    Post
    I'm totally with James B here. I don't think CAT5 would be able to handle the current. Especially 450 watts! Regular speaker wire works just fine.
    BoominVolvo
    http://olymp3.mp3car.com
    May 2000
    Ft Gordon, GA
    Post
    i use cat5 for line out from my hu to my amp. works like a charm and is much nicer than 4 rcas. i did wrap it in foil. i will soon replace it with stp.
    "if everything is under control, you're not going fast enough!"
