Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 34
Thread: Car PC sound, not as good as expected!!
  1. #11
    Mar 2004
    IMO there is only ever 1 option.
    soundblaster audigy 2 zs in a PCI slot running kxproject (google it) drivers.
    I have my PC in boot, giving me a full sound processing active (i.e. 6 channels out, 2 tweets, 2 mids, and 2 subs (Summed)), time aligned, and EQ'd. I run straight from PC to my amp (3 stereo wires) - a McIntosh mc440m ricpf , which then directly drives my McIntosh speakers - no passive x/o required, so more headroom.
    The SQ is better than my old system of a Pioneer DEX-P1r - which is a very good headunit.
    HTH
    Stu
  2. #12
    Constant Bitrate Lando's Avatar
    Apr 2002
    line driver
    Or if you dont want to go the USB route, ther is always a line driver to boost your output voltage from 2 - 8 volts. Higher output Voltage = better sound
  3. #13
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    My USB SoundBlaster was crap and I returned it. Bought an Audigy PCI card off Ebay and it sounds better than CDs on my head unit IMO. No noise whatsoever and my cheap RCAs run right up the tunnel along with every other CarPC wire in the car.
    Fabricator
  4. #14
    i have a sound blaster live 5.1 what would i use to go out from that to my receivers aux input which is 2 rca's?
  5. #15
    Oct 2003
    WI
    2 RCAs after the 1/8" stereo headphone-to-two RCAs adapter.
    Fabricator
  6. #16
    Nov 2003
    Marietta, GA
    Glyn,
    You may want to invest in a ground loop isolator. It helped a lot in my setup. They are everywhere for about $15.
    MikeH
  7. #17
    Quote Originally Posted by Altimat
    thanks do you know where i can find that adapter?
  8. #18
    Low Bitrate Glyn's Avatar
    Apr 2002
    North Wales, UK
    Quote Originally Posted by MikeH
    Glyn,
    I'm sure I've got one of those somewhere.
    I'll have to dig it out and give it a go,
  9. #19
    Apr 2002
    North Wales, UK
    I got myself a Soundblaster MP3+ from ebay, hoping that it would solve all my problems.
    But it hasn't!!
    The costant buzzing noise is still there in the background.
    It must be the car PC because it sounds perfect when played through my Laptop.
    When the computer is idol, the noise is very quiet, move the mouse and it buzzes.
    When music is played, the buzzing can be heard constantly in the background.
    The case I'm using is plastic, so the idividual components do not share the same ground, and the components are not shielded in any way.
    Would this cause the buzzing??????
  10. #20
    Mar 2004
    yes. manually ground all the components imo. especiall PSU, and audio card
  1. will pcchips 748 mobo work as a car pc?
    By hud in forum General Hardware Discussion
    Last Post: 03-10-2004, 09:55 PM
  2. Where to install my car pc in my car?
    By dank_Army in forum Newbie
    Last Post: 02-01-2004, 09:08 AM
  3. Got my PC in the car!!! But it has tons of noise. Help!
    By bombboyer in forum General Hardware Discussion
    Last Post: 12-25-2002, 03:19 PM
  4. My first shot at a mp3 car pc!!!
    By radioman193 in forum General MP3Car Discussion
    Last Post: 08-16-2001, 02:41 AM
  5. About power Supply to PC in car
    By Sk8te in forum General Hardware Discussion
    Last Post: 11-11-2000, 11:39 AM
