Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
Thread: Car PC sound, not as good as expected!!
    Low Bitrate Glyn's Avatar
    Apr 2002
    North Wales, UK
    I finally got my car PC togeter and into the car.
    I am taking the sound straight from the board into an amplifier.
    My problem is that there seems to be a lot of noise/clicking over the speakers.
    Has anybody else found this???
    Is it likely to be that the auidio out lead is not good enough; ie picking up interference??
    Or is it Via's onboard sound????
    I'm using a 800Mhz Mini ITX, powered by a 90W Opus.
    Maximum Bitrate jusatry's Avatar
    Nov 2003
    obviously: check your grounding.
    But if the noise is not alternator whine, try getting a USB sound card and testing sound with that. I suspect its just the poor quality of the audio out.
    Maximum Bitrate falconey's Avatar
    Feb 2004
    Atlanta
    if you can provide as much information about the negatives as possilbe, that way you can get better answers to your question. an example would be to give more description of the sound and when it happens.
    Sao Paulo - Brazil
    Thumbs up Use any board with 2V output
    There are some rules:
    1st: Try to use industrial quality cables, gold plated on connectos, triple shielded preferrable.
    2nd: Try to have them pretty close to the amplifier (shorter cables=better sound)
    and 3rd and more important:
    Use a good quality sound card, such as sound blaster extigy2 Pro, it has a 2V output (2v is the minimum necessary to avoid noise and let the "gain" on the amplifier to an acceptable level).
    If you use a card like this, in addition you're gonna have a "high-end" output, 108dB of S/N Ratio and excellent frequency response... depending on the rest of you equipment (i.e. speakers, amplifiers) you're gonna be able to hear sounds from your favorite songs that you never heard before my friend.
    If you like sound, and wanna "match" the rest of the equipment, try B&W or Mcintsoh amplifiers and "focal" (france) 3-way speakers... you're gonna love it!
    Mar 2004
    I hear a lot of people recommending usb sound cards, is this because everyone has a mini-itx and cant fit a pci card in there system? Reason im asking this is, its cheaper to get pci cards, and the add-on ones dont have noise from the computer/dvd/cdrom drives like the onboard soundcards.
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    IMO the usb is better becsuse you can sit it right next to the amps and just run a long usb to the carputer. Makes for really short and tidy connections.
    2005 Ford Focus ST
    Sep 2003
    Wilkes Barre, Pa
    Quote Originally Posted by gospeed.racer
    That want most people run either a EPIA or a SFF.. The SFF put the PCI card right in the way of the Video card cause them to heat up and lose airflow.. I know this is why my Home PC has a USB Sound Card..
    Apr 2002
    North Wales, UK
    From what you all say, USB sound cards seem to be the way to go.
    The Extigy looks excellent but expensive... Is it really that much better than some of the cheaper ones.
    After all, It's only going to be playing MP3's and radio.
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Anyone know what is the CPU usage like with an external soundcard as opposed to an internal one? Thinking about adding one to my laptop but it is pretty slow.
    Edit: mainly interested in the extigy ones, seem some reports of cheaper ones using a lot of CPU but more info on these would be good too.
    Jan 2004
    yea, are there any usb1.0 soundcards... is usb1.0 (1.1?) fast enough for a soundcard???
    AT mobo
    Intel Pentium MMX 233mhz
    ESS Solo PCI soundcard
    Linksys NIC
    Irman
  1. will pcchips 748 mobo work as a car pc?
    By hud in forum General Hardware Discussion
    Last Post: 03-10-2004, 09:55 PM
  2. Where to install my car pc in my car?
    By dank_Army in forum Newbie
    Last Post: 02-01-2004, 09:08 AM
  3. Got my PC in the car!!! But it has tons of noise. Help!
    By bombboyer in forum General Hardware Discussion
    Last Post: 12-25-2002, 03:19 PM
  4. My first shot at a mp3 car pc!!!
    By radioman193 in forum General MP3Car Discussion
    Last Post: 08-16-2001, 02:41 AM
  5. About power Supply to PC in car
    By Sk8te in forum General Hardware Discussion
    Last Post: 11-11-2000, 11:39 AM
