Results 1 to 5 of 5
Thread: Epia Heat question
    Nov 2003
    Orlando, FL
    Epia Heat question
    my carputer is currently rebooting over an over again.
    I got into the bios for a brief moment and saw the temp was 36deg celcius/100 fahrenheit
    is this the problem?
    Low Bitrate Dr Jeckyl's Avatar
    Mar 2004
    Bakersfield, CA
    most intel chips are stable in the 170-190 (fahrenheit) range, and I can't imagine other chips being much different.
    How much power do you have going to your system?
    If at first you don't succeed, so much for skydiving!
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    Swap out the PSU. It may not be supplying enough power.
    Also, the temp is fine. When it gets to around 65 or 70 Deg. Cel. is when you need to start worrying.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    but mine does the same thing under the same circumstances on any PSU, even with an inverter.
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    I'M DEBT FREE!!
    I'm now a reasonably successful gunblogger.
    Constant Bitrate gubon13's Avatar
    Los Angeles
    at what point does it reboot? does it actually make it in to the o/s at all? does it post? is it consistent when it reboots? what motherboard and processor are you using? what psu?
    "Is Wayne Brady gonna have to choke a b@$#*??!!"
  1. Question to all EPIA M1000 owners
    By bjorne_the_best in forum Power Supplies
    Last Post: 03-29-2004, 12:49 PM
  2. A quick question about EPIA MII
    By Bergetun in forum General Hardware Discussion
    Last Post: 03-17-2004, 08:16 PM
  3. CPU Heat question: Which one would generate less heat?
    By kiztope in forum General Hardware Discussion
    Last Post: 02-12-2004, 02:14 AM
  4. epia m question
    By leeroy1 in forum General Hardware Discussion
    Last Post: 01-04-2003, 02:06 PM
  5. EPIA "tv" out question
    By rbarr110 in forum General Hardware Discussion
    Last Post: 07-17-2002, 05:04 PM
