Results 1 to 7 of 7
Thread: c134 instructions.
    Dec 2003
    Question c134 instructions.
    anyone have the manual for the c134 or know how to open the dang thing, i can't get it figuered out, i am probably missing a screw but don't want to risk it.
    Nov 2003
    Marietta, GA
    Sorry, I meant to answer this for you earlier. There should be two chrome thumbscrews on the rear panel (at the top left & right hand side of the pane). Just unscrew these and pull on the handle while holding the outside of the case. The handle should pull out the inner shell. Be careful because there are several wires running along the side of the case that may get pinched. Here's a photo of the magic thumbscrew...
    MikeH
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    What kind of power are you running in there mike?
    Nov 2003
    Marietta, GA
    Internal power supply is the standard Morex that came with the C134 case.
    MikeH
    Mar 2004
    Redondo Beach, CA
    Quote Originally Posted by MikeH
    I was referring to the 3 wires passing through the hole where the internal PSU input normally is. In any case, I don't want to hi-jack this thread.
    Dec 2003
    thanks i will try that.
    Dec 2003
    USA
    click on the cartft banner and then on the workshop button once the page loads.
    There is a manual for the c134 case there.
  1. which option should i use, c134 or 2699
    By DSM97RS in forum General Hardware Discussion
    Last Post: 03-24-2004, 11:01 AM
  2. Opus PSU for Casetronic C134
    By aethernaut in forum Power Supplies
    Last Post: 02-25-2004, 01:19 AM
  3. DC-DC Converter for C134 EPIA M1000 Nehmiah
    By entr0py in forum Power Supplies
    Last Post: 02-24-2004, 09:22 PM
  4. Using Sealed Lead Acid battery with Casetronic C134
    By MikeH in forum Power Supplies
    Last Post: 11-21-2003, 09:27 PM
  5. Question about ITPS with Castronic C134
    By CedMan in forum Power Supplies
    Last Post: 11-15-2003, 11:12 PM
