Results 1 to 10 of 15
Thread: Two IDE HDD on epia?
    I was thinking using a CF to IDE adapter to store my operating system for the car and using another 20 GB HDD just for mp3s. This may be a bit noob but, would the epia board detect the two drives if they were plugged to the same ide cable or would I need an extra pci ide controller?
    Constant Bitrate parawing742's Avatar
    Jun 2003
    Tennessee
    I've used two hard drive (1 master and 1 slave) on the EPIA-M board without any problems. I don't see any reason why this wouldn't work.
    Phillip Hullquist
    I entertain people through adventure movies.
    www.11visions.com
    Thanks, just did not want to invest into a cf to ide card if it would not work. I'm gonna use a EPIA-V by the way. Must be the same ide controller as the M series...
    Mar 2004
    jplev22, what OS are you running on the CF? From what I've read, CF doesn't hold up long when used like this because of the read and WRITES (really the writes) to it. Are you running an embedded OS?
    Yes, I will an embeded linux system. The embeded kernel I compiled was barely 400 KB. I will run irmp3. I estimate that the total system will be under 10 MB. I can't wait to see how fast it will boot. I believe I will not have anything being writen to the CF during normal operations except for the logs when it boots so I guess it should hold up.
    Mar 2004
    You could make a very small partition on the HDD for log files and set everything on the CF as read-only.
    Sorry if this sound ignorant, but...what's irmp3? What will you use for navigation? I haven't seen any linux ones that can even come near the windows versions yet...
    Newbie awh4992's Avatar
    Jan 2004
    ya the CF will not be too usable when ya start gettin near it's maximum of 100,000 writes. the reads don't matter though, ya can do infinite of those. w/ 100,000 writes and all u'll be doin is writing logs 2 the thing each time it boots, ur CF'll outlast the rest of the computer. w/ ur drives u'll hafta have the CF set to master and the harddrive set to slave. that way the epia won't have any trouble detecting what's plugged in.
    Yep that's what I'll do. Should last a couple years at least.
    jmbickham, I'm actualy only doing an mp3 jukebox right now, I don't have enough money for a gps or even a touchscreen. I'll be using a 4x20 character display and a universal remote to controll the system. IRMP3 is just a daemon (program) to get ir signal from lirc and display all the info to the character lcd with lcdproc. Check it out: http://irmp3.sourceforge.net/ I beleive It is somewhat similar to the winamp character lcd plugin but I don't think winamp has IR cababilities. If it does it would take an eternity to boot anyways. By the way, did you see the project at www.dashpc.com? I did not see windows applications do as well yet...
    Mar 2004
    Quote Originally Posted by jplev22
    I've actually looked at dashpc. It IS nice, but... there are no good GPS in linux. What's there can't compare to the commercial windows version ones.
    As far as windows boot times... if you think of the box as more like a windows CE machine... purpose built. I wonder how stable you could make a stripped down win98/me? Just leave only what's needed to run what hardware and software you have. It would certainly be faster than win2k or winxp...
    Maximum Bitrate Hcomplyr's Avatar
    Nov 2003
    Salem MA USA
    but its the way windows handles the file system that will kill the drive, stupid virtual memory
  1. 3.5 laptop hdd on morex 60w
    By jplev22 in forum Power Supplies
    Last Post: 04-25-2004, 11:45 PM
  2. thin flex IDE cables
    By [H]Bugster in forum General Hardware Discussion
    Last Post: 04-01-2004, 02:28 PM
  3. Original Epia VS Epia M
    By MeanGT in forum General Hardware Discussion
    Last Post: 09-23-2003, 04:25 PM
  4. Slimeline HDD -> IDE Adapter HELP!!
    By sq_geek in forum Classified Archive
    Last Post: 09-20-2003, 10:55 AM
  5. FS: VIA EPIA M9000, 40gb HDD, 256mb, Audigy
    By nc0gnito in forum Classified Archive
    Last Post: 01-27-2003, 04:18 PM
