Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Laptop Power Supply
    Jul 1999
    Greensboro NC
    Laptop Power Supply
    You may have seen info on the Laptop Power Supply from MPJA in a couple other threads. I ordered my LCD and Power Supply from them today. It should all be here in 2-3 days. Ill probably test it as soon as i get it so I will have info very soon. The PS costs 25 bucks.
    I also bought a 16x2 LED backlit LCD from them for 3 bucks. I'll post info on the LCD as soon as I get it also. Check out my site for updates on how my project is going at catlas.mp3car.com
    Aug 1999
    IL
    Thank you very much for the info. If it all works well then this will be a great option. (I hate being the guinea pig!)
    mda
    mda is offline
    Oct 1999
    UK
    I could be wrong here but don't most laptops run on just +5V???
    Jul 1999
    Greensboro NC
    I dont knwo about most laptops but this one ran off of +5 and +12 and btw the powersupply works good...im gonna be putting it in my car soon
    Aug 1999
    IL
    How about those pictures on your site? I want to get an idea of what it looks like.
    Also, what specs do you have running off of it.
    Jul 1999
    Greensboro NC
    The pictures should be on my site soon (just have to get the film developed and scanned) and as for what im running i have a Cyric 233 underclocked to 133 for heat reasons(the chip has already halfway fried the motherboard but it will work until i get a new system) a sound card and HD...i havent tried it on the exact system im using in the car but all the info for the PS (voltage amperage) is in the catalog and just look up the specs on your equipment and see if everything is ok.
    Aug 1999
    IL
    I just checked out the web site for the power supplies and I don't see it anywhere on their online catalog anymore... and the links to the pdf files are gone!
    If you still have the .pdf catalog, could you email it to me? Thanks
    Aug 1999
    IL
    where are those pictures and info??? how is this thing working anyways!
    Jul 1999
    Greensboro NC
    Sorry its taking me a long time to do anything with it...I havent had much free time to mess with i tlately. ive also ran into a small problem. The power supply has a pin type header connector(like an ide connecter only with less pins) but i dont have a cable to hook it up too..A regular IDE cable cant support the current...any ideas?
    Aug 1999
    Yorba Linda, CA
    Catlas -
    You should be able to solder to the pins:
    1. Take some 18AWG wire and strip the end about 1/4". Use different colors for input, grounds, and outputs, and write them down on paper to avoid confusion (and possibly a burned out supply!)
    2. Tin the wire and also the pin on the header you want to solder to.
    3. Solder the wire by placing it right next to the header pin (parallel) and heat it with the soldering iron and let the solder from both the pin and wire flow together. Remove the heat and let it cool.
    4. Slide a small length of heat-shrink tubing (1/2" to 5/8" will work) over the wire/pin junction and heat it to make it shrink tight over the connection (you can use your soldering iron by rubbing the tip over the heatshrink, if you don't have a heat gun).
    This is what I would do. I agree a regular IDE-type ribbon cable wouldn't pass the current -- it's only 24-26AWG wire and would get hot and probably melt!
    BTW: Most laptops need more than +5V to operate -- they need a negative voltage (~-26VDC) for the LCD, and some devices also need +/-12V to operate.
    --Jason
    http://jump.to/m2pc
    Jason Johnson
    Yorba Linda, California
    http://www.m2pc.com
    MPC Phase IV - *** PENDING ***
