Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: SR-8184 iMac DVD not working...
    Apr 2002
    Houston, TX
    Okay, got an SR-8184 Slimline Slot Loading DVD from the iMac off eBay about two months ago.... $15......
    I just now got the ability to test it out and it kind of doesn't work.... The BIOS regonizies it, it shows up in the device manager... all this looks good.... but when I go too insert a disc, I keep pushing and pushing untill there is maybe 1/8" of the disc sticking out and it never respondes....
    It seems to me like the internal mechanics of it are dead..... After running the computer for about 30 to 40 minutes... I could feel it was warm....
    Any ideas???
    Thanks in advance...
    BIOS? On a Mac? There ain't no BIOS on a Mac.
    Try these guys, they might be able to help you.
    http://forums.macnn.com/forumdisplay.php?s=&forumid=73
    Are there really other Mac users in here?
    FLAC Chairboy's Avatar
    Jan 2004
    1. A Mac does have a BIOS, I suspect you're thinking of a the CMOS settings screen you can get to on a PC on boot. A BIOS is the code that lets the computer interact with physical devices attached to it.
    2. I suspect he's trying to use an iMac slot load DVD drive on a PC as part of his carputer. This is mp3car.com, after all, and the Macs have the slot load drives we all covet.
    Apr 2002
    Houston, TX
    Duh what???
    Okay, I am using a PC with the "coveted" iMac slot load DVD.... BIOS.... last time I read the dictionary, BIOS is the firmware that runs the computer and is the repository for all the hardware information and configurations....
    i.e. - it identifies and controls the IDE devices, and it recognizes the DVD drive correctly....
    Actually I thought CMOS was that little Monkey dude in the new Planet of the Apes movie....
    But other than that it shows no signs of life.... I don't know and can't tell if the drive has any power or activity LED's on it, but there is nothing blinking.... it never tries to grab the disc.... it acts like it is totally dead....
    Go figure.......
    Feb 2004
    Elmira NY
    try opening it up.. or sticking the disk ALL the way in.. see if it can spin it up and just not suck.
    or maybe this is why it was 15$
    Jun 2003
    try the suggestion above, opening it up...
    i had a similar problem, and resolved it by trying to figure out the mechanism that pulls the disc in. if i remember correctly, part of the mechanism was stuck, preventing it from pulling in the discs correctly. i think this might happen in shipping.
    hope that helps
    Aug 2003
    Mine's not working either. I haven't used it for a couple months, but last time I used it, it WAS working... *sigh*
    See my other post (just made it then saw yours). Same symptoms, LED lights up, but the DVD drive doesn't seem to want any DVDs pushed in.. *shrug*
    DAMNIT!!
    Variable Bitrate rgardjr's Avatar
    Oct 2003
    Quote Originally Posted by ruzzmon
    hope that helps
    Had same problem with 2 of these drives. I thought the seller just sent me the same drive, but said that he had sent a replacement. Anyway I opened mine up and figured out what had jammed up in the loading mechanism. Put it back together and it worked fine. Haven't used it since.
    Aug 2003
    Quote Originally Posted by rgardjr
    Can you explain how you opened it up? I see 2 screws, one on either side, and then I can't tell how it opens after that.
    Also, once you remove the top (it looks like that comes off), then does anything fall off and have to be re-assembled again??
    It's a little scary, to be honest.. I don't want to mess it up more than it already is..
    Thanks!
    Apr 2002
    Houston, TX
    Quote Originally Posted by sq_geek
    Thanks!
    Well I took mine apart last night, all you do is remove the two TINY screws you see on the sides and then slide the top back..... Getting the screws loose is a *****..... Very small philips head.... I ended up using the smallest bit I had and a cordless drill.... got one to break loose the other got to messed up to grab, so I had to dremel the head off.... It will be fun trying to find a replacement for that...
    Any how once apart I have no clue what I am looking for.... I pushed a disc all the way in and nothing... did this several times.... I was looking for like a small contact or limit switch that would start it up... couldn't see anything...
    Now just to make it more confusing the little motor in there did spin twice for a second or so.... but nothing more....
    Ya know, I was just thinking.... a few minutes after this the whole computer started freaking out (rebooting, crap on the screen, etc).... that got me concerned, forgot about the DVD drive to figure out was was going on with the computer....
    Turned out to be the lawn mower battery I am using in the house was going dead.... so maybe it is working now and the one second deal with the motor running was cause it didn't have enough amps....
    I don't know, have to play some more tonight
  1. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 12:25 AM
  2. Mat****a DVD ROM SR 8186-B
    By Der Me!$ter in forum General Hardware Discussion
    Last Post: 12-30-2003, 09:26 PM
  3. firewirebridge with imac dvd?
    By etrik in forum General Hardware Discussion
    Last Post: 12-20-2003, 11:25 PM
  4. Quest For an imac dvd adapter
    By GuRuGoD in forum General Hardware Discussion
    Last Post: 11-19-2002, 09:45 AM
  5. Got iMac DVD drive - no faceplate - any suggestions?
    By nxt125 in forum General Hardware Discussion
    Last Post: 08-07-2002, 12:49 PM
