Results 1 to 9 of 9
Thread: Quietest fans?
    It's not really that small...No, seriously. judoGTI's Avatar
    Feb 2004
    Florida
    Quietest fans?
    I'm looking for PC fans between 20-80mm but they need to be quiet.
    I dont want a harrier jet trying to take off inside my dash.
    '02 GTI
    [Routis '04] [Opus 90W] [160GB Maxtor HD]
    [Lilliput 7" TS] [VIA M10000] [XMPCR]
    [512MB RAM] [Custom housing]
    [Deluo GPS Mouse] [E-MU 0404 Soundcard]
    Progress Meter: [==============|] 99.9%
    hud
    hud is offline
    Mar 2004
    You want a Panaflo 12L/L1A...
    http://www.svc.com/panaflo-sale.html
    seriously, these are whisper-quiet.
    although, important note: my link above is to the ones that have a 2-pin connector, NOT a standard 4-pin molex connector.
    hud
    hud is offline
    Mar 2004
    also, i know that the NMB brand of fans that dell has used in their PCs are very very quiet too.
    rochester ny
    I second panaflo.
    Oct 2003
    Toronto, Canada
    the larger the fan is, the slower it has to spin to move the same amount of air. Hence you shouldnt be looking at anything below 60mm if you want a really quiet fan. Get one of those huge bastards with some super new bearing technology
    Never used panaflo but 21db seems to be damn good.
    VIA Epia II
    256MB 266DDR Ram
    90GB Wester Digital
    Bluetooth/Deluo GPS
    Lilliput 7" Touchscreen
    Mazda 6 Carputter > Click Me!
    Nov 2003
    Seattle, WA, USA
    If you want ultra quiet, and willing to spend a little more, then Papst is your fan. The Papst 8412NGL fan is marketed as the most quiet fan in the world. Noise level 12db!
    http://www.endpcnoise.com/cgi-bin/e/00025.html
    Feb 2004
    Elmira NY
    get a panaflo or Papst witch are some of the best. get the bigest you can. 80mm or biger
    and run it at lower voltage to slow it down for even less noise
    Constant Bitrate Homebrew's Avatar
    Maryland
    Panaflo L1A series are definetly great fans. I use the 80mm panaflo L1A series fans in every computer i build. They're only 21db. A relative newcomer to the scene is SilenX. I haven't used any of their fans personaly, but if their specs are correct, they're the new king of quiet. They're fans are quieter than just about everyone else's and they produce more airflow. Compare SilenX's 14db 80mm fan to the Panaflo 80mm L1A.
    SilenX
    28cfm
    14db
    Panaflo L1A
    24cfm
    21db
    Papst 8412NGMV
    20.6cfm
    13db
    Now let me tell you, the panaflo 80mm L1A is quiet. The Papst and SilenX fans are listed at a third less db. They should be very silent. The SilenX produces the most cfm of the three with only 1db more than the papst. Now I'm not dissing papst fans, they're great fans, but sometimes its hard to get a specific model papst. I don't know how easy or hard the 8412NGMV is to find, i just used it in the example because it was the 80mm papst with the best noise to airflow ratio. The drawback to all 3 fans i listed is that they're not cheap. If you look hard enough you can get the panaflo 80mm for $3-$4. On average you seem them going for around $9. I'm not sure about the Papst fans, but i believe they go for around $8-$10, maybe more. The silenX fan is $13.95. Not cheap, but if it lives up to it's specs, it maybe worth the money. You can find specs on many other fans on the following site:
    Gizzo's fan page
    You can check out SilenX's here:
    SilenX
    Hope this info helps.
    -Kevin
    Mar 2004
    Quote Originally Posted by NewTechFool
    Wow thats some nice fan they got there. I always said German engineering is the best, how I wish I could afford a German car
    Never be afraid to do something yourself. Remember - amateur built the Ark, professionals built the Titanic.
  1. fans
    By LudeAtude in forum General Hardware Discussion
    Last Post: 04-23-2004, 01:55 PM
  2. VW fans
    By Sh0cker in forum Off Topic
    Last Post: 11-12-2003, 07:13 PM
  3. FrodoPlayer - For you 800 x 480 fans 18 Oct
    By frodobaggins in forum Software & Software Development
    Last Post: 10-18-2003, 04:30 AM
  4. Those who run fans for cooling??
    By osirisdon in forum General Hardware Discussion
    Last Post: 06-12-2003, 09:30 AM
  5. Any anime fans in the house?
    By ShinkunoNamida in forum Off Topic
    Last Post: 06-29-2002, 09:49 AM
