Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Need Long Ide!!!
    Aug 2003
    Angry Need Long Ide!!!
    I finally got this blasted slimline IDE DVD player working 100%, but now I need a longer IDE ribbon/cable to get the DVD player from my trunk ("boot" as some of you call it) to the front dash. The run is just under 15 feet.
    ANY IDEAS?
    I would prefer not to do some kind of USB -> IDE enclosure or firewire -> IDE enclosure.
    I've heard of people using shielded CAT-5 to run the wires over longer distances.. I would need 5 of those (x 8 wires each = 40 pin)...
    Thanks in advance!
    Constant Bitrate Aftaab001's Avatar
    Mar 2004
    Kent, UK
    No offence but search more...this time search for IDE to USb 2.0 converter!!Good luck
    Aug 2003
    Yeah, but then you have to power it separately.. It's a total PITA, cuz then you have power to the USB converter and power to the DVD drive still..
    Too many wires I think..
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    how about making one.....get a couple IDE connectors and this cable ($.49 a foot) and you are good to go
    2005 Ford Focus ST
    Aug 2003
    Oh man, no way.. I don't think that will work.. 15feet???
    Doesn't it need to be shielded and grounded or something?
    Dec 2003
    Portland, OR
    Quote Originally Posted by sq_geek
    I didnt think the cat5 would work either though....did the other post ever come to any conclusion as to what the max length of either of them are? I thought I read that the 80 pin was not the greatest, because the wires are so small, but the 40 pin stuff was decent. As far as shielding though, not really sure. I would be very hesitant to run anything but usb or firewire that far myself, but I know what your saying on the running 5v to it as well. I am sure there are usb devices out there that draw all their power from the usb port, but this would be bad as well, over this distance anyway. There has to be a better answer.
    2005 Ford Focus ST
    Mar 2004
    I would say its VERY unlikely an IDE cable is going to work at 15ft long, reguardless of the shielding. The maximum size according to the spec is 24". There are also signal timing isssues to take into account, not just interference. The one thing you could try though, is (assuming this is possible BIOS), clocking the bus down to ATA33. This isn't going to be a big deal for a CD drive anyways, and would give the bus a better chance at working.
    Feb 2004
    San Francisco
    Do some more searching. I saw a thread on this board of a guy that had an ide cable of about 15, and it worked fine. Even had a picture, he had it going accross his living room.
    Aug 2003
    OK, I found the guy Leslie33737 or something..
    He is using an 80pin IDE cable...
    What is so special about the 80pin? My Motherboard only accepts 40pin, so what do the other 40 pins hook up to?? How do I wire this?
    Thanks!
    Kevin
    Aug 2003
    The thing is, this guy paid like $40 shipped for a long IDE ribbon..
    I just want to make my own. I can get the 80-pin IDE roll (50') from Fry's or something and make my own..
    I just don't know how you wire it to a 40-pin connector.. ANY IDEAS???
    Thanks!
  1. 5 meter long IDE cable for sale.
    By Mastero in forum Classified Archive
    Last Post: 12-31-2003, 12:13 PM
  2. LONG IDE Cables
    By handyandy in forum Input Devices
    Last Post: 12-31-2003, 02:16 AM
  3. Long (36") rounded IDE cable.
    By ddt in forum General Hardware Discussion
    Last Post: 05-07-2003, 05:30 PM
  4. never lose focus
    By marsjell in forum Software & Software Development
    Last Post: 08-12-2002, 02:18 PM
  5. long ide cable-update
    By albysure in forum General Hardware Discussion
    Last Post: 07-01-2002, 09:49 PM
