Results 1 to 10 of 15
Thread: Anyone using Commell LV-670 P4 mini ITX?
    Raw Wave
    Jun 2003
    Not too sure which are the suitable case for the combination below
    The board - Commell LV-670 Pentium4 mini-ITX motherboard
    http://www.ultim8pc.co.uk/index.asp?...products&idd=3
    The suitable PSU - Silent 110W ATX PSU Kit :
    http://www.ultim8pc.co.uk/index.asp?...roducts&idd=17
    Like to know how good they are.
    TIA
    Raw Wave
    Jun 2003
    Anyone?
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    I thought about it....though the Commel 671/PentiumM combination is much better. However most applications in a car just don't need that kind of horsepower AND have such a restriction on space. So, most people go for VIA because it is small and cheap. If I wanted more power and size wasn't an issue I'd probably get a micro-ATX m/b and an Athalon-M setup.
    If you need the ooomph and want a teeny PC footprint the the commel 671 is perfect or the task.
    Maximum Bitrate ddogg_777's Avatar
    Apr 2003
    HOT Arizona
    My Commell LV-671 is supposed to arrive tommorrow by UPS!!!!
    Raw Wave
    Jun 2003
    I agree but Im just not too happy about the pentium M price, performance and availabilty. The heatsink mounting for it is also smaller...not sure if this can be bought easily. If all are readily available for reasonable price then I guess Ill go for 671.
    Lucky you...which PSU, case and processor you buying for it and where from?
    Apr 2003
    HOT Arizona
    I have my own plexicase that I made for my M10000, I will just cut out a bit for the pcmcia slot. The 1.5Ghz M chip (not P-4Ms) I picked up new for $75 on ebay (I saw two 1.7ghz M chips go for $50 BIN, gotta be fast!). The PSU is the Opus 150W that opussolutions said they would modify free of charge.
    Constant Bitrate Homebrew's Avatar
    Maryland
    ddogg_777, where did you get the LV-671 from? Also how much did you pay if you don't mind me asking? I've been considering this board but from what i've read on the boards, the cheapest its been found is $325. Also, I'd love to hear a review of the board once you've gotten a chance to play around with it.
    -Kevin
    Raw Wave
    Jun 2003
    Same here
    Apr 2003
    HOT Arizona
    Variable Bitrate NoPistonPC's Avatar
    Boston
    Quote Originally Posted by ddogg_777
    What are the advantages of this setup over something like a VIA EPIA P4 ($185) + 1.7GHz P4 ($50)? A PW-60a would provide more than enough power and the CPU comes with a quiet cooling fan (which is inaudible in a moving car). Basically, why would you want to spend extra money on a Pentium-M or a motherboard that supports a Pentium-M? It would make sense in some applications, but I don't see the advantage for a CarPC... Maybe I'm missing something...
  1. Mini ITX MB? HELP
    By fondoo in forum General Hardware Discussion
    Last Post: 05-06-2004, 08:46 PM
  2. VIA Mini ITX P4 MB $190 shipped
    By tbdombrosky in forum Classified Archive
    Last Post: 03-18-2004, 01:27 PM
  3. no mini itx between 1ghz eden and P4 2.4Ghz?!
    By Henke in forum General Hardware Discussion
    Last Post: 02-04-2004, 05:11 PM
  4. Anyone using the P4 Mini ITX?
    By SavageKabbage in forum General Hardware Discussion
    Last Post: 01-22-2004, 12:16 PM
  5. mini itx and xp
    By oddcomp in forum General Hardware Discussion
    Last Post: 09-16-2002, 03:20 PM
