Results 1 to 8 of 8
Thread: Where to get a small case???
    Cue
    Cue is offline
    Jun 2000
    Post Where to get a small case???
    I have a pretty small motherboard and Im looking for a small case like one from a book pc or something, anyone know where to get one? I would rather buy on, but if not I guess i will have to make one.
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Post
    You don't say what size you need. I used a 11.75"x6"x2" aluminium case from Maplin, it's perfect for a biscuit mobo, DC2DC power supply and a laptop harddrive. All you have to do is drill it for your air flow and connectors.
    The link is (I have the PC25):
    https://catalogue.maplin.co.uk/products/detailsframe.asp?SKU=1728&partcode=LF14Q:LH10L:LF1 0L:LF13P:XB71N:LF08J:LF16S:KR56L:XB69A:LF11M:KR55K :KR57M:LF12N:&cart=909133547&d=f&type=1& SecData=%5BeqSectiondata%5D&GroupData=METAL%20ENCL OSURES&SubGroup=GENERAL%20CASES
    They also have larger cases to if this isn't big enough. Since they are aluminium, you can use it for heatsinking your PSU chips if you want (that's what I do).
    Rob
    -- <A HREF="http://www.nav.to/robwithey" TARGET=_blank>http://www.nav.to/robwithey
    </A>
    Newbie Etho's Avatar
    Jun 2000
    Arnold, Mo. USA
    Post
    I found a person that will sell the book pc case Here is the reply from him.
    "Bare book PC, either AMD or Celeron version w/52x CD ROM: $200.00"
    mp3pc@aol.com
    Take it for what it is worth.
    Etho
    Car - 20%
    PC - 80%
    Planning - 90%
    Cue
    Cue is offline
    Jun 2000
    Post
    That is more than likely a quote for the barebones book pc, if it was for the case he would not specify celeron or AMD,the reason he is becasuse it has the motherboard and cdrom etc. in it already, by the way you can get that for $159.00, 200 Is expensive.
    Feb 2000
    FL
    Post
    Cue,
    I noticed you talking about this in our earlier discussions on the NLX form factor thread.
    What for factor is this Mobo? ATX, mini ATX? AT?
    Check out http://www.allelectronics.com
    in the cases section they have a small type case which was surplus from some small AT&T terminals. I bought one but never used it. I think it was like 15 bucks. All metal construction No power supply tho :-(
    Offroad
    Offroad
    06' F-150 FX4 4x4
    MII12000 and StreetDeck
    Jun 2000
    Arnold, Mo. USA
    Post
    Ok I am sorry I forgot it to say but it is for the board, powersupply and cd-rom and case. Where can you get it for 159.00? I was lucky to run across that guy but hey your research is better than mine.
    Etho
    Car - 20%
    PC - 80%
    Planning - 90%
    Mar 2000
    Portland, OR , USA
    Post
    Hmm, that AllElectronics case sounds interesting. Here's their description:
    METAL ENCLOSURE:
    Exterior dimensions: 12" x 12" x 2.5". Front panel has a cut-out for a 1/2 height drive. Vents in sides and rear. Plastic front panel with AT&T logo. Case and front panel only. Originally designed for a small AT&T computer. CAT # MB-67 $6.00 each . 10 for $50.00
    I was gonna build my own, but for $6.00 I'll give this one a try.
    Oct 1999
    CA
    Post
    I bought one and it came in the mail today. The thing is very tiny, and it has room for a PCI card (which the bookPC doesn't). Does anyone know what form-factor this thing is, and how to mount drives and a power supply in it? It looks like it might be NLX, but I can't tell for sure.
