I use a large drill bit to get it started then cut it with the Dremel. Too hard to do it with a plasic cutter. I found a thin engraving tool for the dremel and at high speed it cut through acrylic like butter (because of the friction and heat), it should work the same for plexiglass.
LinkBack URL
About LinkBacks
