Results 1 to 3 of 3
Thread: will not shutdown
    Dec 2003
    will not shutdown
    the carputer, now will not shutdown, it looks like it is about to shutdown, and it says saving settings, and then says shutting down, but is just stuck there, if i disconnect the usb orinoce client, it works like a charm, what seems to be the problem, also on the client when it says shutting down. the link and power light are on steady
    Raw Wave wizardPC's Avatar
    Jun 2000
    are you using the winxp drivers or the orinoco drivers for that card. It's most likely a driver issue
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    I'm now a reasonably successful gunblogger.
    Dec 2003
    i think it is the orinoco, since xp wouldn't pick it up. is there any bettery drivers
  1. prob with mucha shutdown controller
    By geebee in forum Power Supplies
    Last Post: 12-08-2004, 10:30 AM
  2. New Improved ATX Shutdown Unit!
    By Danceheaven in forum General Hardware Discussion
    Last Post: 04-15-2004, 10:52 PM
  3. Keyless Entry Shutdown Controller
    By Sinorm in forum Power Supplies
    Last Post: 04-07-2004, 09:30 PM
  4. Can you adjust shutdown voltage on Opus 150w?
    By Visual Echo in forum Power Supplies
    Last Post: 03-26-2004, 09:04 AM
  5. startup shutdown etc.
    By marsjell in forum Power Supplies
    Last Post: 06-19-2002, 07:07 PM
