OHH .. that plug is called motorolla connector ?? hmm .. learn something every day LOL
hey everyone
after seeing this post: Which antennas for tv cards?
by amrit50 in regards to how he's using his radio antenna for tv reception (using the specified connectors) I did some searching around and found a few things:
This looks like a female motorola to a female coax (could plug directly into tv card?): http://www.walcottcb.com/coax/coax/12mfpl.php
but this by far looks like an awesome solution:
http://www.walcottcb.com/coax/coax/pdc64.php
this will split your radio antenna to the standard motorola male connector and a bnc connector. then you could just get a bnc coupler and a female bnc to type f coax. with this you could then keep your factory radio or use the motorola connection to somehow hook up to your specific radio.
or i guess you could stick to amrit50's setup and add a bnc t connector and use one output for the tv and one for the antenna:
http://www.radioshack.ca/estore/Prod...log=RadioShack
what do you guys think? any suggestions? has anyone done this or anything similar/better?
Thanks,
Chris
