Results 1 to 4 of 4
Thread: Using Battery Charger in the House?
    Apr 2002
    Houston, TX
    Using Battery Charger to Extend Battery Life?
    Okay, I have never really had a good understanding of amperage and current flow.... Here is the issue...
    I have the CarPC all together in it's case, and have been running it off a 12VDC lawn mower battery as I work on the final hardware issues. It would be very difficult to hook it up to a standard ATX PSU right now and run it from AC.
    But now I have to reformat the HD and get the software the way I want it. But this lawn mower battery does not have enough life to do a full HD format and install Windows before the voltage drops too low and it shuts down.
    If I had the computer running off the battery, doing what I said above, and attached my car battery charger to the lawn mower battery, would I fry something in the CarPC?
    The charger has two current setting (2A and 10A) and I think this means it forces 2A or 10A to the battery and whatever else might be hooked up..... I know the system is drawing more than 2A, so it seems to me like it would extend the battery life so I can get the software stuff done before the battery runs dead. Now maybe the 10A setting would be too much, I don't know....
    The whole deal just makes me nervous.
    What do you think???
    Variable Bitrate MeanGT's Avatar
    Jul 2003
    Melbourne, Florida
    I used to run my Heavy load 12v devices directly of my car battery charger. I would set it to the 50-amp jump start setting. Just becaues the charger is putting out up to 50 amps, doesnt mean you will over-power your PSU, the PSU will only take how much amperage it needs. If you think about it, a car battery can put out many hundres of amps and cause no harm.
    The only problem I ran into using the battery charger, is that the power output is quite a dirty signal, so you may get interference or noise when using it.
    My OLD Carputer: http://www.mp3car.com/vbulletin/showthread.php?t=17412
    Currently, Don't have a carputer :( I sold my lincoln and bought a '93 Acura Vigor, plan on putting a carputer in it one of these days. You can see my vigor at: This Site
    Apr 2002
    Houston, TX
    Quote Originally Posted by MeanGT
    Thanks for the info MeanGT.... I just can never comprehend current.... I was under the impression that Battery Chargers "Forced" current to whatever is attached to them...
    But I guess not based on you using a 50A setting... by the way, what do you mean by "Heavy Load 12V devices"????
    Jul 2003
    Melbourne, Florida
    Quote Originally Posted by dug1967
    I frequently find myself repairing things such as head-units, and amplifiers for myself and friends, and rather than lugging in a 12v battery to test them, I just bring in my battery charger. A true power supply that puts out enough current to handle these items can be quite pricey.
  1. Can I put an extra battery in my Chevy?
    By Mastiff in forum Power Supplies
    Last Post: 11-04-2008, 12:45 PM
  2. Battery based tank circuit (tested)
    By Ricky327 in forum Power Supplies
    Last Post: 02-13-2008, 05:43 PM
  3. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
  4. laptop battery pack charger?
    By mrzigzag in forum Power Supplies
    Last Post: 12-07-2003, 07:36 AM
  5. Laptop battery died
    By jol in forum General Hardware Discussion
    Last Post: 08-22-2003, 04:55 AM
