Results 1 to 4 of 4
Thread: HELP! Changed bios setting now can't see screen!
    Jan 2004
    Hi,
    I read a couple of posts on the net about changing the type of screen in the bios to LCD to improve performance, now I can't see the screen!
    Can some kind person tell me the exact keyboard steps to change it back to CRT + TV in the advanced chipset menu.
    Think i need:
    From bios, to advanced chipset features
    Then to the screen type
    Then to CRT + TV
    Escape then navigate to save bios and exit
    Can somone give me the steps for above?
    please! Im fooked if i can't do this
    Regards
    John
    Constant Bitrate Aftaab001's Avatar
    Mar 2004
    Kent, UK
    Flash your bios. easy wat motherboard have you got? just look for the flash bios jumper and it will change everything to default. Make sure you remove the atx power connector before flashing
    Mar 2004
    Kent, UK
    if you got an m10000 its located pci slot is "pci facing towards north ". on the left hand side of the battery. the red little jumper just remove it and connect the other pin wth the middle one by usind the red jumper for about 2 secs and replace everything to normal
    Aug 2003
    or pull the little battery out and boot your puter up. it will lose it's saved cmos/bios settings and will go back to defaults. then put it in, and boot again and tweak the settings again in the bios and then save them.
  1. Replies: 21
    Last Post: 08-27-2006, 02:26 AM
  2. via bios startup screen change
    By Cliff in forum Software & Software Development
    Last Post: 07-10-2003, 03:37 PM
  3. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
  4. Replies: 13
    Last Post: 07-02-2002, 11:54 AM
  5. Redant screen - widescreen, screen res, TV out???
    By Griffin_Dodd in forum General Hardware Discussion
    Last Post: 02-06-2002, 07:09 PM
